Dell Dimension 8400 PC Desktop Logo
Posted on Mar 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
"my computer will only beep no screen,it beeps 5,2,2,1 times
"my computer will only beep no screen,it beeps 5 times, 2 times, 2 times and 1 time and stops
Anonymous
Level 2:
  • Expert 58 Answers
  • Posted on Mar 14, 2009
Anonymous
Expert
Level 2:
Answers
58
Questions
0
Helped
37812
Points
154
3answers
2003 f 250 super duty truck five beeps five times
5 beeps 5 times - Ford Truck Enthusiasts Forums
www.ford-trucks.com > ... > Super Duty & Heavy Duty
Jan 2, 2009 - 5 beeps 5 times Super Duty & Heavy Duty. ... 2003 F250 4x4 CC V10 4" Procomp, all white beauty "list of previous owned Fords much to long to ... Beeping under my dash
Jun 17, 2012
Getting these strange beeps from Dashboard
Nov 13, 2010
beeping noise
Dec 22, 2009
5 beep tones 2000 f250
Turn on. No screen. 6 beeps followed by 5 beeps.
Hi Anonymous,
Request you to try following the below steps which might help:
(1)Turn off the computer.
(2)Remove all the external peripherals like AC Adaptor, flash drives, battery, etc.
(3)Press and hold the power button for 30sec which releases the static on the computer (if any)
(4)Put back the battery and plug in the AC Adaptor.
(5)Let the computer charge for some time.
Now check and let me know if there are any status lights and how many times the computer beeps?
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Laptop beeps 7 times
Try link: http://blog.parts-people.com/2014/06/27/dell-inspiron-m501r-m5010-beep-codes-diagnostic-indicators-2/ How to identify beep codes: When a laptop or computer first powers on, it goes through an initial set of diagnostic tests to make sure vital components are preforming correctly. These tests are called POST or Power On Self Test. When a test fails, the user is notified via POST codes, Light codes, or Beep codes. For diagnosing Beep codes you need to:
  • Power on the laptop or restart it if it is already on.
  • Listen to the number of consecutive beeps when the computer begins to boot. Restarting the laptop may be necessary and should not harm the laptop at this time.
Dell Inspiron M501R (M5010) Beep Codes # of Beeps Description Possible Cause(s) 1 BIOS ROM checksum in progress or failure System board failure, covers BIOS corruption or ROM errors. 2 No Memory (RAM) detected Memory or Memory slot failure 3
  • chipset Error (North and South bridge error, DMA/IMR/Timer error)
  • Time-Of-Day Clock test failure
  • Gate A20 failure
  • Super I/O chip failure
  • Keyboard controller test failure
System board failure 4 Memory read / write failure Memory failure 5 Real Time Clock (RTC) power fail CMOS battery failure 6 Video BIOS test failure Video subsystem failure 7 CPU Cache test failure Processor failure or motherboard failure 8 LCD LCD failure Most Common Fixes:
  • 1 Beep: Replace the motherboard / system board.
  • 2 Beeps: Reseat the memory or replace the memory.
  • 3 Beeps: Replace the motherboard / system board.
  • 4 Beeps: Reseat the memory or replace the memory.
  • 5 Beeps: Replace the CMOS battery.
  • 6 Beeps: Reseat or replace the video card or replace the motherboard / system board.
  • 7 Beeps: Reseat or replace the CPU or replace the motherboard.
  • 8 Beeps: Reseat the LCD cable or replace the LCD screen.
Dell inspiron 15 beeps 7 times
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
Will not power up
DELL BEEP CODES
While booting the tower, it is beeping 5 times (instead of one time) - short break - beeping 2 times. there is no signal towards the screen...
Those are beep codes. Going to need to figure out what kind of motherboard it is, and look it up here: http://www.computerhope.com/beep.htm
The sound of hardware failure is too happy, imo.
2answers
When starting up the computer, I get 5 short beeps then continous
These beeps seem to show that your system did not detect any RAM (memory) modules connected to it. Please check.
  1. Open the CPU case (turn the PC off first)
  2. Remove the RAMs from the slot.
  3. Turn ON your computer without the RAMs installed. Then observe if it gives the same beeps. If it is the same, then the RAMs might fail to register.
  4. Try to plug in carefully the RAMs in place. If you have 2 RAM modules, try to test 1 RAM at a time to see if the combination of the 2 mess up your system.
2helpful
3answers
Hi
You likely have a bad memory module. First, try removing all the memory and putting it back in again. This is called reseating. If you still get the errors, then try removing one stick at a time and testing it with each stick (provided, of course, you have more than one stick installed). If you only have one stick installed, remove it and turn on the computer and it should beep at you as well. That memory stick will need to be replaced.
Thanks and please take a moment to rate this solution as fixya. Thank you.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
