Re: how do I instert a micro SD adaptr into a HP windows...
Micro sd are too small usually, you need a Micro to SD sleeve, you simply slide the micro into an SD size sleeve and then just put it in your SD slot if no micro slot etc, or buy a usb multi card reader , hey presto
You can transfer pictures to your laptop by using a Micro SD card reader like the one in the image:
Insert the Micro SD to the slot which says "Micro SD" and then plug it in the USB port of your laptop. The laptop will soon detect the Micro SD. Open "My Computer" and then choose the removable drive which is usually E: or F: or G:. Thanks.
that all depends on the model of your laptop, most current laptops have a slot for a standard sd card, if this is the case you will need a micro sd adapter.
if you dont have a port for an sd card you have 2 options, first you can buy a usb memory card reader (making sure it takes micro sd cards before you purchase) or, most mobile phones take the micro sd card so you can put it in your phone and either plug it into your laptop using a usb cable and try getting them that way, or if you can view the photos on your phone, bluetooth/email them across.
you need to either purchase a micro sd card adapter or a usb memory card reader, they are both pretty cheap and available in most supermarkets/electrical outlets but cheaper still on ebay/amazon/play etc it all depends how fast you need it.
If you have no SD slot on your laptop, you will have to buy an external USB SD reader. They typically cost $5-$10, and are readily available online (e.g. http://www.buy.com/prod/micro-sd-sdhc-card-usb-reader-for-1gb-2gb-4gb-8gb/q/sellerid/23962916/loc/101/213271933.html) or in almost any store with a good selection of electronics.
I can't find a Scan Disc pro Que, but I can find a Sandisk Pro Duo, which is a micro SD card.
You will need either an adaptor or a USB cable which can connect the device which uses the card to you laptop.
There are a couple of types of adaptor, one basically converts the micro card to and looks like an ordinary SD card. The other looks like a USB flash drive which you slot the micro card into.
Really cheap on Ebay. Just search for a Micro SD card adaptor.
most mini sd cards come with a full-sized sd card adapter that the mini slips into. You can then slip that in your computer if you have an sd slot or sd reader. You can also buy very inexpensively, a usb port mini sd reader that you can plug directly into your usb port on your computer. Then after you'v dragged and dropped the files, you can put the mini sd back in your phone.
