Question about LG KU990 Viewty
My lg ku990 has yellow sreen
I tried 2 put flash program in my lg ku990 now it wont work and has yellow screen
Posted by james_dodds on
  • donmcgregor Mar 18, 2009
    i have a question i not sure if yuh can tell me how to correct it ....i follow the steps perfectly on backing up the firmware ..how ever when i disconnected the hit yes ..my phone will not move from the yellow refreshing screen.. plz help...
Anonymous
    Sniper:
  • 65 Answers
Iyourfatherl
maybe this will work.
conect your phone with the usb port.
start in windows the program EFS MEDIA BUILDER by AKOM1976.
select connecton and after that you choose efs explorer select connection.
Now you see the files on your phone
maye there is a folder named as TOTO
be sure that this folder is on your phone!!!
If it does delete the folder named as LGAPP
after that rename the folder named TOTO to LGAPP
richt click and choose refresh.
now exit the efs program.
Turn your phone off and then after a few seconds on
the phone will startup normaly as always and its normal asual.
I hope this will work or you have to back up with the LGMDP euro
an after that choose restore and choose the image file *.nv2
This will work!
Posted on May 01, 2009
Anonymous
    New Friend:
I have the same problem as urs...i was backing up then, and suddenly the yellow screen was there and it never returned to its normal...i used to do all of the techniques uve shown here..nut sadly, it didnt work at all..how am i supposed to do...i rename TOTO into LGAPP then refreshed it,then disconnected it..then restarted it..and same as before...its yellow refreshing mode again...pls help!
tnx!
Posted on Sep 01, 2010
  • Anonymous May 11, 2011
    http://www.fixya.com/support/t2141371-sc...
    Take a look at this section be patience and read the instructions your issue will solved!
    Best regards Henk.
Anonymous
Replay to PuerkoNess
Can you please send me direct link? Thank you!
Posted on Aug 11, 2009
Anonymous
Replay to
LG_Authority
You said when you go to EFS MEDIA BUILDER connect your phone and all that . you said you see files in your phone. but i dont know were my files go . theres like no files. no TOTO file or LGAPP watever it is. HELP PLEASE what am i suppose to do?
  • Anonymous Aug 11, 2009
    can you please give me the direct link ? Please. thank you !
Anonymous
  • 275 Answers
Go to www.mygreatphone.com they have a KU990 Wiki that has all the steps on how to fix the evil yellow screen.
Posted on Mar 18, 2009
Anonymous
    New Friend:
  • 48 Answers
Software update on your phone at www.lgmobile.com
and dont use emfbuilder
Posted on Mar 15, 2009
STUCK ON YELLOW SCREEN(REFRESHING)WHILE USING EFS MEDIA BUILDER FOR LG KU990 VIEWTY
There is either a virus on the phone, or you have too many large files on the phone. This 2 might cause the phone to operate on a very slow mode or might be freezing.
When receiving or downloading a file, there might have been a virus on the file, and that can corrupt other files on the phone, including its firmware.
First of all, remove the battery and insert it back in, if it does the same, then try to flash the phone with the appropriate software. Remove the memory card and try to scard it with a computer or laptop using a memory card reader, then you check for the files if there are any viruses.
Also ensure you do not have too many files on the phone and the memory card in order for the phone to work at a high speed.
Take care and good luck
Orange messenger wont work on my LG Viewty KU990
ask for help, you might have broke your service antenna
Yellow refreshing screenon lg viewty what is this and how can i get my phone working again
Look at this issue: My lg ku990 has yellow sreen.
Answer:
http://www.fixya.com/support/t1793053-lg_ku990_yellow_sreen
I am sure this will fix your yellow screen that coms up on the start.
Read and take a lot of patience when you do the job.
I am sure thhis will help you out!
Best regard:
Henk®Muskita© 2009.
I can't connect my lg viewty with the refreshing problem to my pc
please try to connect your lg to some some another pc, perhaps it will work, keep it up
My phone KU990 was in the middle of backuping and the usb cable accdently fell off and the yellow screen appeared with the text refreshing... i tried pressing it, taking out the battery and connecting to...
sounds like you need to reflash your phone back to it's original settings.
you'll need the following:-
LGMDP software - this allows you to flash the phones internal file system
'your specific network firmware'.DZ - this is lg's own firmware with the network settings in a .DZ file.
if you go to http://www.mygreatphone.com/forum/modifications-hacking/12356-ref-rollup-firmware-backups-hacks.html#post91633 all the info you need is in there. i could tell you all about it here but i'd just be repeating what's in the forum.
don't worry, it can be sorted
<JAIMO>
1helpful
LG KU990 flash not working
look through the user manual, if no info there take to a phone shop and they should be able to help you...
I hope this was some help!
2helpful
5answers
Can not connect KU990 to PC through USB
The CD that comes in the pack is does not work on Windows Vista. if you do not have Windows Vista, try to add the LG suite into your firewall (if you have one). You do that by goin into control panel and selceting firwall. Once done that go into setting then expectaions and then add a program. hope this helps.
19helpful
5answers
LG viewty Touchscreen problems
I have the same problem. But i had solved it. I use a lighter to burn on my viewty's touch screen, and it is working properly again within 30 secs. And ofcourse, do not burn the touch screen without a screen protector. Hope this solution would help.
LG KU990 Viewty Logo
Top LG Computers & Internet Experts
Ekse
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
