Question about Maytag Washing Machines
Maytag washer wont start after it fills
It fills with water and wont run on any cycle. replaced lid switch, didnt help. Does not make humming sound like its trying to run.
Posted by kagregor on
Anonymous
Did you replace the pressure switch its a round plastic thing with a plastic tube at the bottom and six electrical connections
Posted on Mar 14, 2009
Anonymous
  • 38 Answers
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • click the link http://www.applianceaid.com/norgewash.html#pulley
Maytag dependable care plus will fill up with water but wont start cycle
sounds like you have a bad lid switch part 3949247 and it's around 50 dollars.open the lid,look at the right side,you'll see a hole,stick a screw driver into the hole and push down easy with the machine set on spin,if it doesn't spin and when you push up and down on the switch with the screw driver the lid switch is bad.watch video
http://www.youtube.com/watch?v=V5aW9WkTFhE
Mar 29, 2013 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore 300 model 110.28322700 won't run. motor makes humming sound
Pre Thanks for help.
I have read all above and these are my symptoms.
1. Washer fills, may or may not agitate, will not advance to the rinse cycle, and will NOT drain - lid switch.
however i tested my lid switch with a multimeter and the lid switch seems to be fine.
What else could be my issue?
Kenmore 300 110.28322700
Dec 03, 2011 | Washing Machines
Our washer is filling with water but will not run the cycle after it fills. We were able open and close the lid and it would start but now it only fills with water...Please help!!!
the lid switch is buggered the lid can be open while its filling but when it goes to start washing the lid needs to be shut so the lid switch isnt working so the machine thinks the lids open.
Jan 05, 2011 | Maytag Washing Machines
Only the rinse and spin cyl wont work on my whirlpool
first check the lid switch,open and close down the lid and listen for a clicking sound,if you don't hear it clicking you have a bad lid switchtry opening the lid with it on spin and stick a screw driver or anything that will fit in the hole where the lid closes down into the hole where the lid switch is,if it runs then you know the lid switch is bad.also on washers,in the rinse cycle only cold water is used in the final rinse,no cold water the washer won't fill and run,the valve will just hum.let me know how you make out,you could also have a bad timer.if you need more help send the model number
Dec 05, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Wont fill when it goes to rinse cycle just sits and hums
There's no water at all If there's no water at all, make these checks: Is there water getting to the machine? Is the water-volume selector switch set properly and are the control panel buttons pressed in all the way? If you have a Maytag® washer, is the fuse (if there is one) in the control panel at the lid-switch bracket blown? Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve.
Jan 01, 2010 | Kenmore 15864/15862 Top Load Washer
The washer will fill up with water but won't complete the cycle or drain. This has happened before, and I would spin the knob a few times and switch the load size selection. It always randomly started
it sounds like a bad timer there....! if after you selected a different load it drained......!
if it didnt drain at all on any mode I would say a bad lid swtich.
May 27, 2009 | Maytag Washing Machines
Will not start wash cycle
Sound like the lid switch has went out , you should hear it click when the lid is close to an inch of being closed , they are un-expensive and easy to replace and they go out often from use. Easy to find online with your real model number located under the lid.
Phil
The washer with the grind noise is a main bearing going out and may be covered under warr. through maytag.
Apr 11, 2009 | Maytag Atlantis MAV7000
Won't run
sounds like your lidswitch.when you close lid you should hear or feel it click on and off.located on back side of lid in center.
Mar 10, 2009 | Maytag LSE7806A Top Load Stacked...
Washing machine fills, but won't agitate
Lid switch if its a Maytag Alantis... You said you have a GE top load in the start of your problem and ended witha maytag?
Dec 18, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Wash cycle will not start
you may have leaned on lid and damaged the lid switch , so the washer thinks the lid is open all the time unit will fill then stop with lid up.
Apr 13, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
717 people viewed this question
Top Maytag Washing Machines Experts
John Tripp
John Tripp
jdthefixer
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
