Josh Hoshor Posted on Mar 14, 2009
Need wire diagram 4 altec lansing acs295 4 red connctor
Broke three pins off the red connector that plugs into speake out on subwoofer. if you can give me the wiring diagram for that plug on model #ACS295. Thank You
johannluus
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Nov 11, 2010
johannluus
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2374
Points
6
I have the same speaker set. maybe we can help each other. My plugs are all fine but my sub is not connected to anything at all and I need to know were they must go on the pc board. Maybe we can trade some photos on the wiring diagram?
I have a Altec Lansing multimedia computer speaker system ACS295 but I bought the speakers separate from the subwoofer so the two speakers have a different CHW number that the subwoofer has how can I make...
Numbers do not have to match as long as the Ohms are equal. Usually 8 Ohms per speaker is normal. The low impedance allows you to attach the wires without getting a shock. The most that happens is a tone of sorts. Just align + to + and - to -
1helpful
Is there a way to use the Altec Lansing VS4121 Subwoofer as a stand alone?
Normally these low end system components depend on each other and cannot be interchanged with components from other system. So if one of the components (subwoofer or right control satellite speaker) breaks or gets lost the whole system is unusable...
I was in the same situation. Got a subwoofer from VS4121 without original satellite speakers. I acquired satellite speakers from Altec Lansing 251 which used same connectors but the internal wiring was different and incompatible. Speakers are also glued together so it is impossible to open without damaging it. Obviously there is no service documentation anywhere..
But if you like electronics you can try to make something based on the information below:
Altec Lansing VS4121 connector pinout:
Take the male connector (from right satellite speaker) and number pins in first row from left to right as 1-3, pins in the second row as 4-7, pins in the bottom row as 8-9 and the circle enclosure as 0. Then:
0 - Ground
1 - Speaker Right
2 - Treble (seems just like voltage control but may need to be confirmed: Min=0V; Max=voltage from Volume control Pin 9)
3 - Head Set Right
4 - Bass signal (not sure what the exact original design is as I have not opened the speaker) But seems like they use 50K potentiometer and some sort of RC low pass filter configuration. When potentiometer is set to Min it is shorted with ground. When set to Max it is taking signal from Right and Left Head Set (pins 3 and 5) combined through some larger resistors and low pass filter.
5 - Headset Left
6 - Ground for Headset (grounds 0 and 6 seems to be connected in the subwofer but within the right satellite speaker they seem to be isolated with separate leads to sub)
7 - Power ON/OFF. When OFF or headset jack plugged then 0V. When ON and headset jack unplugged then 5V
8 - 5V Power in
9 - Volume (min=0V; max=5V). It seems they use 50K potentiometer but probably anything >10k should work.
At minimum for standalone subwoofer you will need to implement:
- Power On/Off (switch between pins 8,7)
- Volume control 50k potentiometer (probably anything between 10k and 50k will do) between pin 7 and 0 with variable output to pin 9
- Bass control - join two resistors R (I used 7k) and call this join point A. Attach other ends of the resistors to pins 3 and 5 respectively. Attach 50k potentiometer (I used 10k) between point A and ground 0. Attach Variable pin of the potentiometer to pin 4 (Bass input signal). Attach capacitor C between Pin 4 and Ground pin 0 (I used Electrolytic 1uF with negative end to ground) . Resistor R and capacitor C should make simple passive low pass filter (Google for formula) that should short any frequency higher than 80-120Hz to ground and feed frequencies lower than 80-120Hz to pin 4.
PS: I managed to hack 251 control satellite speaker to somewhat work with VS4121 Subwoofer but that is another subject. All electronic parts were salvaged from old broken TV so total cost was $0 but took several days of tinkering for speakers that I could buy used for $10-20 :)
8helpful
2answers
9 pin diagram altec lansing
can anyone help me with the Altec Lansing VS4121 2.1 Channel i need the wiring diagram of 9 pin cable i broke it. please mail me the layout at [email protected]
ACS295 speaker cable to subwoofer, one of the pins of the connector is broken, how can I fix it or get a new connector?
if connector is broken, you need to buy a new connector, but it takes a little handwork and some tools a screw driver some electric iron and solder.
u need to open subwoofer case and check for the connector is soldered in a board is 2 jack 3,5mm female connector and one red mini-DIN connector. replace the connector take a attention on soldering the connector, dont damage the board wires and pins, if the iron above 300ºC.
take a special attention on electrostatic discharge, normaly burns sensitive boards.
12helpful
2answers
Need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
3helpful
2answers
Wiring diagram for Altec Lansing Vs4221 Right Speaker Wire
red-positive . blue-negative and if another colour mostly brown-Earth.
Top Altec Lansing Audio Players & Recorders Experts
Steve Sweetleaf
Steve Sweetleaf
 Grubhead
Grubhead
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
