Televison & Video Logo
Posted on Mar 14, 2009
My 19 inch ge tv makes buzzing noise can it be
My 19 inch 'G.E.' tv makes buzzing noise can it be fixed?
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Mar 14, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
993
Points
11
I've had this happen on a couple of TVs, it's always been from moisture getting into the back of the TV. I've been told by a few techs that the issue is beyond economical repair on older televisions.
Wall plug for TV buzzes
Have the outlet checked by a qualified electrician. Sounds like either a power issue or ground. You should not get a buzz from an outlet for any reason.
If you plug something else into the outlet does it make the same noise?
If yes, something going on with the power. If not, then the TV power supply might be doing it, but the noise would be behind the TV and not the outlet.
1helpful
Acer lcd screen p191w makes a buzzing noise when turning on and the screen is very dim. then it shuts off. can this be fixed at home
Not safely and not unless you are confident and competent with electronics. I would put the dimming down to a failing display circuit, but the buzzing sounds as though a short is developing. I would take it to a tv repair shop who can advise better and maybe replace or repair the components
My samsung 42 inch hdtv is making a buzzing noise
First. The whirring or buzzing sound you hear is the Color Wheel and it needs to be replaced. Second, since I do not know when and if the original lamp has been replaced it is a good idea to replaced the lamp. The bad Color Wheel is the one causing the set to shut down.
GE spacemaker is making a buzzing noise sometimes when it cooks?? How can I fix this?
make sure the screws around the back and on the light access panel are all tight -- it may be the cabinet buzzing.
Buzzing noise from 42 inch Samsung Plasma TV
this is a comon occurance in theis model it is caused be loose laminants in the switching tranformer sometimes it can be fixed by covering it with clear GE silcone
2answers
Spngbob TV Makes buzzing noise when plugged in and wont turn on
Bad horizontal driver or output transistor/trnsformer. Look for serious service for this set...accordianman
Top GE Televison & Video Experts
ExpressFiX
ExpressFiX
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
