LG 32LX3DC 32 in. LCD HDTV Logo
rudy hettrick Posted on Aug 07, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LG 32LC2D HDTV
I bought a tv in February and its giving me static on my screen. It's not the type of static you'd get if you had air wave cable, but more digital. Its getting more common. Almost everytime I turn it on now, it comes on after 20 or so seconds. Please help?
Les Davis
Level 2:
Sergeant:
  • Expert 247 Answers
  • Posted on Mar 09, 2008
Les Davis
Expert
Level 2:
Sergeant:
Answers
247
Questions
Helped
36022
Points
622
Many TV's with an LG plasma display (or built by LG for other manufacturers) have a manufacturing defect that has been reported widely on the Internet. LG, Akai, SamsungLG 32LC2D HDTV - 1.gif and Zeneth among others.
The sparkles are (usually red) visible on a black background with all inputs after the set has been used approximately one year. Soon after a pop is heard and the picture no longer shows at all.
LG and some other manufacturers using the LG displays have not acknowledged this defect and will only repair them free during the warranty.
Often techs will merely adjust voltages and or picture controls, which does not fix the problem but it just disguises it -- until the display blows -- usually after the warranty expiration.
I own a 42" Akai that is 9 months old that has recently been showing the red sparkles. My set is being replaced.
You should contact service if your set has this problem is under warranty and it should be replaced at no charge.
Good luck. :)
Have LG plasma tv model 50PG20 static on audio all the time.
If you wish to get advice over phone; visit https://www.6ya.com/
It's an absolutely free service, and so many experts are online. a 24hour/365day service.
Why does the screen go black and sound go off and I get an intermittent a chattering static type noise? When I turn TV off and on again the sound and picture sometimes return for a few minutes then ho
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time.
LG 32LC2D tv is taking 35 minutes tu turn on
If you can darken the room when first turn set on and have sound, take a small light (flashlight) and examine the screen, DO YOU see a faint image of the picture on the sets screen?
Most use a back light and it may not be coming on correctly.
To learn more Google BACKLIGHT IN TV.
1helpful
Static noise on my lg 42LS3400 TV - NOT THE CABLE
The main power supply switching regulator board has the fault. Contact the nearest authorized service center for LG
TV only works for 5 minutes then blank screen, not blank off, blank no signal, signal is fine. 32LC2D
Nothing you're gonna be able to fix yourself... Sorry but you're gonna have to take it somewhere to fix that particular problem
3helpful
Sound problems
Contact your LG dealer to request a service call out, it is very possible the operating software requires to be updated to the latest version especially if you have had the TV for quite a while. Once this is done if the problem still persists then there will be a problem with the audio processor & this will need replacing.
LG 22" Flat Screen HDTV
the Svideo, not Saudio, will have to be selected in the tv's input menu, but Svideo won't give audio, you will have to connect audio leads to the TV and to the sat box or whatever you are using for your programmes
Digital Static
try changing you sky box.. or freeview.. i did.. no problems now
LG lcd tv 32lc2d
Many TV's with an LG plasma display (or built by LG for other manufacturers) have a manufacturing defect that has been reported widely on the Internet. LG, Akai, Samsung1.gif and Zeneth among others.
Good luck. :)
Marvin
Marvin
Kolbrun...
