When plugging dvd player into component plugs, picture shows in greyscale/ bluish colour. sound works fine. when plugging the same dvd player, and testing with same disc, in the AV plugs colour and sound both show as normal. a DVD player was previously working on the component platform without problem.
SOURCE: Grey Screen
Try the reset on the remote. Press this key twice to restore factory settings. The TV will automatically start Channel Search and clear all customized settings. These features will automatically reset: ? Picture/Sound Adjustments: Color, Tint, Contrast, Brightness, Sharpness, Color Enhancer, Tone, and Surround Sound ? Channel Memory ? Audio to Stereo ? Caption to OFF ? V-Guide to OFF ? Aspect Ratio to 4:3 (normal) ? Menu Language to English ? Sleep Timer (if previously set) ? Video to TV (if previously set) If desired, personal settings can be made again using the menu options
SOURCE: SANYO Model CLT2054 Television
sounds a lot like you lost the video driver or control board functionality. From the 'decay' of your image, with sound still working, and all else being good, you're primed for a new video controller. Are you inclined to do the repair yourself? The service manuals are hard to get online, but the local service center MIGHT sell you one.
SOURCE: Finding AV channel to connect DVD to TV
first check if you are plugged in the right place,(you're tv as 2 a/v inputs).then you should be able to acces a/v by the menu button on you're remote,or even on the t.v. itself.well good luck then buddy,hope this helps.. btw,are you plugged in a/v (yellow,white,red) style,s-video(1cable)style,componentstyle(green,blue,red).check that out man!
SOURCE: Sanyo 68cm. AV1 is Black and White. AV2 and normal Tv is OK
the two AV1 and AV2 have different inputs on the IC,
the first port has a disconnection,
take your tv for a check up
