The water has just started to go really slowly into the washing machine - this used to happen with just the hot water function but now the cold water is really slow. We can't afford to buy a new machine so is there something that we will be able to fix or check to see what the problem is?
Check to see if there's good water volume coming through the hoses attached to the washing machine. If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve.
Q - My washer fills slowly with water, what can I do ?
A - Two things could be your problem...
1) - sometimes the screens in the fill valve or inside the ends of the fill hose get clogged up...use a tooth brush to clean them out. Don't forget to shut off the water first before removing the hoses to check for this.
2) - The fill valve itself may not be opening fully = time for a new fill valve.
Posted on Mar 14, 2009
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
heatman101
If
Washing
Washing
heatman101
If
Washing
Washing
heatman101
