Fold the top of the back seat down. My 1990 civic lx has a place to put your key at the top to release the seat. Remove the trunk carpet from the seat back by pulling out the plastic screws. Remove 2 bolts (10 mm) on each side holding the seat on a bracket. The top part of the seat should now slide out. Once you get the top part of the seat out, a bolt should be exposed just to the right of the center of the seat bottom attaching it to the floor. Unscrew the bolt. Now tip the seat bottom up and forward. There are two hooks to the front of the seat bottom. You will have to move the seat back and forth a few times to unhook them and then pull the hooks out of the slots on the floor.
Callout
Component Name
Notice: Refer to Fastener Notice in the Preface section.
Fastener Tightening Specifications: Refer to Fastener Tightening Specifications .
Preliminary Procedure
Remove the rear compartment floor stowage compartment tray. Refer to Rear Floor Trim Plate Replacement .
Nut, Rear Seat (Qty: 6)
Tip
Roll the seat forward enough to get access to the nut that attaches the center seat belt assembly to the floor.
Tighten
45 N?·m (33 lb ft)
Bolt, Rear Seat (Qty: 3)
Tip
