Question about Palm Tungsten E2 Handheld
Screws for palm tungsten e2
What is the type and size of the 4 case screws in my palm tungsten e2 pda
Posted by zzzzzzzzzzip on
wayne chamberlain
  • 89 Answers
T5 or T6
Posted on Mar 13, 2009
How to change from com 1
Palm (PDA) - Wikipedia, the free encyclopedia
https://en.wikipedia.org/wiki/Palm_(PDA)
WikipediaThe Palm Treo 700p is one of many smartphones produced that combines Palm ... Although HP kept the Palm brand initially, all new PDA devices announced at press ....In order to try to change this trend Palm had been working on a new ...
How to Replace the Battery in Your Palm Tungsten E2 PDA ...
? 4:34
https://www.youtube.com/watch?v=caJVwecskho
Sep 2, 2007 - Uploaded by Aaron Kelly
How to Replace the Battery in Your Palm Tungsten E2 PDA. Aaron Kelly ... for battery replacement. Includes one year money back guarantee!
[PDF]Handbook for the Palm Tungsten E Handheld - Textfiles.com
pdf.textfiles.com/.../PDA/PalmOne%20Tungsten%20E%20Handheld.pdf
Chapter 1: Setting Up Your Palmā„¢ Tungstenā„¢ E Handheld . . . . . . . . . . . . 1. System requirements . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Jan 03, 2016 | Palm Computers & Internet
My computer crashed. I have a backup of all my Palm files but am having trouble recovering them. Does anyone have instructions on how to restore backup files on a Palm Tungsten E2?
Hello.
Palm backups are located in the following directory: C:\Program Files\Palm\username>\ED\Backup\
When you HotSync a PDA that has undergone a hard reset, HotSync will compare the two devices. When it sees that the PDA is empty, it will attempt to reload any backup that exists on the PC. Once this data is reloaded, the PDA will ask to do a soft reset. This is simply a restart of the device and doesn't affect any of the newly installed data. This returns the PDA to working order, with all the data and programs functioning as they were before.
Hope this resolves your problem.
Jan 23, 2011 | Palm Tungsten E2 Handheld
Hello, it seems my palm Tungsten E2 is not compatible with Windows 7 (hotsync). Anything I can do or is there another PDA that will work? Thanks, I do need the PDA.
you need to uninstall the version of palm desktop that you alredy have and install the 4.14 palm desktop, with the hotsync manager that 4.14 includes you should have no more problems
Feb 01, 2010 | Palm Tungsten E2 Handheld
Need Hot Sync module on backup PC
Plug your E2 into your pc and when it says new hardware found, install the cd. Do not continue till you have verified sync connection between pc and pda
Dec 11, 2008 | Palm Tungsten E2 Handheld
Palm tungsten E2 touch screen unresponsive
I noticed this problem with mine and solved it by loosening the 4(four) T5 screws in the back. The problem is caused by a swollen battery. When the PDA is left charging for extensive periods of time, as mine was(several months of inactivity and never thought to unplug it), the battery will swell. It's still a good battery and holds a charge, but the increased girth presses on the internal boards of the PDA causing the screen to register a continuous "touch" and therefore seems locked. It's actually waiting for the phantom touch to release so it can act. Unscrewing the fasteners allows the body to expand, thereby releasing the pressure on the screen and letting the phantom touch go away. I'm going to see how well my e2 does without the screws in it at all for a few days. The front and back panels have "clips" molded into them which hold to the side frames, keeping it closed. But the fasteners are there to ensure the PDA doesn't fall apart all together. So, wish me luck. I'll report back in a few days and update this.
Oct 25, 2008 | Palm Tungsten E2 Handheld
Palm tungsten E2
As the previous responder said, the Tungsten E2 cannot read cards over 1 GB. However, there is a wonderful solution available at PalmPowerups.com called PowerSDHC. This wonderful little driver will enable the E2 to read cards of any size! At $20.95, it's a bargain. I installed it on my E2 and now I use an 8 GB SDHC chip!
Sep 13, 2008 | Palm Tungsten E2 Handheld
Expansion card
Has this card worked before in your Palm?
Jun 30, 2008 | Palm Tungsten E2 Handheld
Replacing battery in Tungsten E2
Sounds like the battery you got is bad. You should get it replaced.
Jun 23, 2008 | Palm Tungsten E2 Handheld
Audio doesn't work on Tungsten E2.
I was reading about this guy who'll do it for alot less here's the URL to the page
http://www.alaskarails.org/palm.html
If you wanted to do it yourself youll need to get a PDA repair kit for 9.95 from pdasmart.com and pop it open (4 torx screws and use a shim tool to pry it open , be careful) and follow anti static procedures ( touch a metal object frequently ) once open check the contacts for the speaker and while your at it the head phone jack if they look fine they may need cleaning. use your favorite electronics cleaner and clean them. This is only if your lucky you'll probably need to replace one/both by placing a soldering iron and melting the contacts off and getting a replacement part and soldering it carefully in place, you'll get a replacement from another broken T|E \ T|E2 or from a PDA replacements parts store of your choice
a refurbished T|X at PDAsmart will cost you $199 if I were to spend any money it wouldn't be at the Palm repair shop
Jun 13, 2008 | Palm Tungsten E2 Handheld
Tungsten E2 PDA battery
E2 has a great battery might not be it. Its not easyly replaceable like in some other models.
the battery can be replaced by a professional or by yourself.
The pda should work on charger? does it work while pluged in?
If it doesnt work while its pluged in theres something more seriour wrong with it.
You can try soft and hard reseting.
Instructions can be found in this pdf file http://www.palm.com/us/support/handbooks/tungstene2/en/maintain.pdf
If you cant open pdf files you need to find yourself pdf reader, google pdf reader and get one.
If soft or hardreset have any effect and the device still doesnt work even on charger then it has a hardware issue and I recommend contacting palm or the place where you bought the pda and findout about repairs and possible price, may be high.
good luck and if theres anything else let me know.
Feb 19, 2008 | Palm Tungsten E2 Handheld
Palm Tungsten E2 Handheld Logo
245 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
NOEL
NOEL
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
