Digital Products Hewlett Packard OfficeJet J6480 InkJet Printer Logo
Posted on Mar 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I set cutom media size on a J6480?
How do I set custom media size on a J6480?
Thomas F. Schneider
Level 3:
  • Master 2,715 Answers
  • Posted on Mar 13, 2009
Thomas F. Schneider
Master
Level 3:
Answers
2715
Questions
Helped
1106389
Points
6961
2answers
What are die sets used for?
Die sets are used for cutting and shaping of materials. They generally use a press and a mold that are cutomized for the item they are making.
When I copy to photo paper it reduces automatically, why
Print on special and custom-sized media
To print on special or custom-sized media (Windows)
1. Load the appropriate media. For more information, see Load media.
2. With a document open, click Print on the File menu, and then click Setup,
Properties, or Preferences.
3. Click the Paper/Features tab.
4. Select the media size from the Size is drop-down list.
To set a custom media size:
a. Click the Custom button.
b. Type a name for the new custom size.
c. In the Width and Height boxes, type the dimensions, and then click Save.
d. Click OK twice to close the properties or preferences dialog box. Open the
dialog box again.
e. Select the new custom size.
5. To select the media type:
a. Click More in the Type is drop-down list.
b. Click the desired media type, and then click OK.
6. Select the media source from the Source is drop-down list.
7. Change any other settings, and then click OK.
8. Print your document.
To print on special or custom-sized media (Mac OS)
2. On the File menu, click Page Setup.
Chapter 2
28 Use the device
3. Verify that the correct printer is selected.
4. Select the media size.
5. To set a custom media size:
a. Click Manage Custom Sizes in the Paper Size pull-down menu.
b. Click New and type a name for the size in the Paper Size Name box.
c. In the Width and Height boxes, type the dimensions and set the margins, if
desired.
d. Click Done or OK, and then click Save.
6. On the File menu, click Page Setup, and then select the new custom size.
7. Click OK.
8. On the File menu, click Print.
9. Open the Paper Handling panel.
10. Under Destination Paper Size, click the Scale to fit paper size button, and then
select the customized paper size.
11. Change any other desired settings, and then click OK or Print.
Print borderless
Borderless printing lets you print to the edges of certain media types and a range of
standard media sizes.
NOTE: Open the file in a software application and assign the image size. Make
sure the size corresponds to the media size on which you are printing the image.
You can also gain access to this feature from the Printing Shortcuts tab. Open
the printer driver, select the Printing Shortcuts tab, and select the printing
shortcut for this print job drop-down list.
NOTE: Borderless printing is not supported on plain media.
To print a borderless document (Windows)
2. Open the file that you want to print.
3. From the application, open the print driver:
a. Click File, and then click Print.
b. Click Properties or Setup.
4. Click the Paper/Quality tab.
5. Select the media size from the Size is drop-down list.
6. Select the Borderless Printing check box.
7. Select the media source from the Source is drop-down list.
8. Select the media type from the Type is drop-down list.
Print borderless 29
9. If you are printing photos, select Best from the Print Quality drop-down list.
Alternatively, select Maximum dpi, which provides up to 4800 x 1200 optimized
dpi* for optimum print quality.
*Up to 4800 x 1200 optimized dpi for color printing and 1200 input dpi. This setting
might temporarily use a large amount of hard disk space (400 MB or more) and will
print more slowly.
10. Change any other print settings, and then click OK.
11. Print the document.
12. If you printed on photo media with a tear-off tab, remove the tab to make the
document completely borderless.
Change settings from an application for current jobs (Windows)
To change the settings
1. Open the document that you want to print.
2. On the File menu, click Print, and then click Setup, Properties, or Preferences.
(Specific options may vary depending on the application that you are using.)
3. Change the settings that you want, and then click OK, Print, or a similar command.
Change default settings for all future jobs (Windows)
1. Click Start, point to Settings, and then click Printers or Printers and Faxes.
- Or -
Click Start, click Control Panel, and then double-click Printers.
2. Right-click the printer icon, and then click Properties, Document Defaults, or
Printing Preferences.
3. Change the settings that you want, and then click OK.
9. If you are printing photos, select Best from the Quality drop-down list.
dpi*.
print more slowly.
10. Select the media source. If you are printing on thick or photo media, select the
manual feed option.
11. Change any other print settings, and then click Print.
How can I print invitations size 5X7 on this printer.
You need the driver setings on your pc, select the correct paper type or media type then select the size if this size is not available you can create a custome paper size one the driver but you must take into consideration on how thick is your paper you can set the media thicker setting all this option is available on the printing preference (windows) or print settings (mac).
hope this help
2helpful
2answers
How do I make my tv pic full screen? My tv programs are shrunken to small screen...
GO TO MENU ON UR REMOTE CONTROL AND SELECT PICTURE SETTING .....
THIS OPTION WILL GIVE U THE PICTURE SIZE ON UR SCREEN U LIKE TO SEE....REMEMBER NOT ALL PROGRAMS ON TV ARE IN FULL SCREEN MOODE
2helpful
How do I find the minimum margin settings for my printer- HP J6480
The margins for US letter are 3mm (0.12 inch) (Top, Bottom, Left, Right)
You can customize certain media. The instructions for doing so can be found in the user manual beginning on page 25. Download it from:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=3635378&
Please rate this solution. Thanks.
1helpful
Anyway to use the custom paper size in Vista??
follow the instructions to change the setting
  1. open ms word
  2. click on file
  3. click on page setup
  4. click on paper tab
  5. and change the paper size.
3answers
No sounds for alarm texts calls or windows media
Mine did that and I just changed to profile and changed it back to normal and it worked. I hope it helps
I want to increase virtual memory of my computer
Hi
From Start Menu --> Open Control Panel
From the various icons listed, open --> System.
System Properties window will open.
Select "Advanced" tab from this.
From the Advanced tab Click the Performance--Settings button
Again from the Performance Options window that just opened select the advanced tab
From this Click the Change Button for Virtual Memory.
A new window for Virtual Memory opens
Select the partition on which your OS is installed [windows]
Then click the Custom Size --> radio button
The text box infront of Cutom Size will be active.
Enter the size as you wish but usually virtual memory is double the amount of RAM on your system.
eg.. If you have 1gb RAM then virtual memory can be less than or equal to 2gb.
But make sure your HDD has enough space to accomodate the virtual memory.
Custom EQ
You have to be in music mode when the player first comes on
Top Digital Products Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Digital Products Office Equipment and Supply Expert? Answer questions, earn points and help others
