I have a Panasonic CT 2762VWhen I turn the set on, a line of color appears across the center of the screen. Rest of the screen is black. After a few minutes, sometimes, it will start to do a circular motion and get bigger. I can get full picture by pushing the Action button on front of set--sometimes.Any and all help will be greatly appreciated.ThanksJim
The line of color is due to a failure in the vertical circuit. The main suspects are the vertical Ic AN15525A and/or capacitor c308 220uf@35volts
If you have the capacity to do so, you should check the other electrolytic capacitors in the vertical circuit which are USUALLY located near the vertical IC in most cases
you can purchase the part at
https://www.encompassparts.com/webwiz/wwiz.asp?wwizmstr=WEB.SEE&partnumber=5760279&smodel=CT32SL15N
or mcm electronics
