Question about Timex Ironman Watches
Split/lap vs lap/split display
I have a Timex Ironman Sleek 250-lap watch and have been using it for about 3 months. It previously displayed all laps in Lap/Split format, however a couple of days ago it changed to Split/Lap format and I am not sure what caused it. Does anyone know how to change the format back to Lap/Split format (so that the Lap times are in the larger numbers)?
Posted by Bronwyn Wakefield on
Tom Chichester
    Top Expert:
  • Timex Master
  • 57,285 Answers
Try Googling (timex)(250)(manual) without parens for information.
Posted on Oct 11, 2017
2 Related Answers
Anonymous
SOURCE: Timex Expedition sports watch - how to view lap times?
I ran into the same problem w/ my new Timex Expedition. I emailed their help desk and they said that the Expedition models do not have lap memory feature. You need an IronMan watch to get lap recall. Wish I knew that before getting this Expedition watch...
Brian
Posted on Jan 09, 2009
Anonymous
SOURCE: Timex Sleek stopped beeping when I replaced the battery
I had this problem. I simply flipped the metal plate on the back 180 degrees.
I noticed on the inside of the metal plate a pad about the size of the battery, and guessed from the other notes that this must perform some kind of insulating function. Furthermore, the writing on the outside of the metal plate was not oriented "up"... that is if I was holding the watch in front of me like I was reading it, the writing on the back plate was upside down. Both of these clues led me to believe that the plate had been re-installed wrong. Flipping it around fixed (restored) the beep.
Posted on Feb 07, 2010
I just need online instructions to use the lap timer on my Women's Timex Ironman Triathlon watch. I'm not sure of the model, but I think it's a 50-lap, and it's small. The 4 buttons on the side...
Here is the link that can help you set up your watch. Also here is the All list of timex watch downloadable instruction.
I hope this can help you resolve your issue.
Thank you for choosing Fixya
Mar 06, 2011 | Ironman Timex T5B721 Sports 50 Lap...
Timex T5E451 instructions PDF
Hi.
This model should be an Ironman 75-Lap Sleek (OVA).
Here the manual:ENGLISH.PDF
Here manuals for different Ironman models.
Regards.
May 15, 2010 | Timex Ironman Triathlon 75-Lap Sleek OVA -...
How can i recall multiple laps during a run?
The Timex Ironman 30 Lap also has a stopwatch that can be used to keep track of split times for racing sports like running or cycling. Press the "Mode" button until the display shows "Chrono," then press and hold the "Set/Recall" button. To start the timer, press the "Start/Split" button. It will continue to run even if you exit to another mode. Pressing the "Stop/Reset" button will stop the chronograph. To record a split time, press the "Start/Split" button again while the timer is running. To see your split times, press the "Set/Recall" button while the watch is in Chrono mode. You can then scroll through the various splits with the plus and minus keys. Press "Set/Recall" again to exit display mode and return to the timer.
Sep 17, 2009 | Timex Ironman 30 Lap 53952 Wrist Watch
Timex Ironman 30 lap heart rate does not display
the battery type is written on the back of the watch.
Jul 12, 2009 | Timex Ironman Tri 30 Lap Sleek T59671...
This is a common problem when non watch educated people are changing battries themselves.
The answer is simple: While changing battery and handling the watch you did lost the coil spring. It is so small, you will never notice that the something was dropped.
Coilspring is the connector to the sound membrane of the watch, transfering microprocessor signals to audible membrane.
If it's lost, there is no connection between watch movement and audio membrane.
I suggest that you did change batteries yourself previously and had the same outcome (no sound). Next time you gonna change the battery - make sure you do not turn the watch upside down and if you do - check the movement with eyeglass and make sure all the loose fitted bits are in place.
To get your both watches fixed visit your nearest watch repair shop and ask for coilspring to be fitted.
Rate me, please.
Mar 26, 2009 | Timex Ironman 30-lap, Blue And Silver From...
Watches Logo
104 people viewed this question
Top Timex Watches Experts
Janelle Schoonover
Janelle Schoonover
Andrew Taylor
Andrew Taylor
 Mikey
Mikey
Are you a Timex Watch Expert? Answer questions, earn points and help others
