Washing Machines Logo
Posted on Mar 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fisher paykel smartdrive 601
My fisher Paykel smartdrive 601 is beeping continuously before the rinse cycle and won't move on to the rinse cycle. I have tried turning it off and pulling it out of the wall, but it doesn't help.
Anonymous
Level 1:
Problem Solver:
  • Contributor 17 Answers
  • Posted on Apr 19, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
17
Questions
0
Helped
28298
Points
28
Most likely a blocked pump
Anonymous
Level 2:
Scholar:
  • Expert 72 Answers
  • Posted on Apr 18, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
72
Questions
0
Helped
24951
Points
145
Mabee ??? mine had the same problem and the water level switch thru inspection they have a resin coated resistor or cap loses continuity so what i did was put 2 cable ties across the legs and tighen them to pull them closer together =0=
l l and worked like a charm but also blow back thru the hose by mouth to see if its not blocked fit hose on good
let me know how you go
  • Anonymous Mar 23, 2010
    Ok so mine was a temporary fix finally it crashed and burned so i bit the bullet and ordered a new module 190 bucks from f&p brisbane plus delivery now they assholed the old modules and have the new ones but i also checked the pump ohm first should be 33 ohm watch the clip that holds them in and ist up and running dont forget to reset the bowl level read the paper that comes with it
Anonymous
Level 2:
  • Expert 144 Answers
  • Posted on Mar 27, 2009
Anonymous
Expert
Level 2:
Answers
144
Questions
0
Helped
82949
Points
350
I can talk you through diagnostics if you want to go on live chat cheers
I have a Fisher and Paykel Smartdrive 9 washing machine that won't fill. It starts then stops and continues to do so, then stops altogether and beeps. Can anyone help??
The error code is displayed when its beeping.
I don't know the error code, so It can only be three things,
Out of balance switch,Lid magnetic reed switch,Or Rotor position sensor,Your error code would help me work out witch one of these are faulty. to work out your error code look at picture below.
Add up the lights that are on.
Hi I have a Fisher and Paykel Smartdrive 601, and the cold water is dribbling out when I put it through a cycle, do you know what the cause is, and how can I fix it??
Your cold water valve is not seating when off,
Try swapping the hot valve for the cold to see if that will fix the problem. if it fixers the problem buy a new cold valve.
1helpful
Fisher Paykel washing machine Smartdrive 703 Advance, Power and Start buttons are non responsive when pushed. Is there a part that can fix this. Does the control panel have to be replaced?
Fisher & Paykel Smart Drive beeps and stops during rinse cycle. If I hit pause and wait and restart it eventually continues. It seems like it has problems detecting water level.
My fisher and paykel smartdrive 708 stops at rinse/spin cycle with machine still full of water
with no error code ... I would check you drain pump or drain hose... you first may want to try a shop vac connected to the end of a drain hose .. let me know if it helps
2answers
Fisher and Paykel Smart Drive 608 wont spin
remove the pump from underneath front right move whith clip forward the twist pump out.but you will need to remove all the water first you may a ball of lint stuck in the pump.hope this helps.
Fisher n Paykel Smartdrive 9
Most waashers rinse with cold water and if your cold water screen on the valve is plugged and it can't let water in it may cause your problem.
Top Fisher and Paykel Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
