Question about Garmin NUVI 360 GPS Receiver
Garmin suddenly doesn't turn on unless plugged in.
The button doesn't feel like it depresses. will turn on if plugged in and must turn off by hitting reset
Anonymous
    New Friend:
Hi there, I have a question, can you fix my garmin 360. its out of warranty and the unit just wont turn on. if you can please email me at [email protected]
let me know what i need to do if you can fix the unit and how much you would charge.
thanks
Posted on Mar 04, 2010
SHARCNET-USA
  • Garmin Master
  • 2,130 Answers
Posted on Mar 01, 2010
2answers
Why brake lights wont turn off?
What has happened is the switch on the brake peddle has moved. Reach under the dash and locate the switch and adjust it so the peddle is depressing the button.
3answers
Dark screen
It's either the logic board or some component that has gone bad. No real way to repair it, unless you tear it down and it's maybe a bad joint or something simple like that.
Best I can tell you to do is to FULLY discharge the battery, as in turn it on, let it die and keep pushing the power button to make sure it's dead. Takes about 48 hours. Once you do that, plug it in and DO NOT try to turn it on, just let it do it's thing and see what happens. Maybe hooking it to a computer after that and seeing if an update will help, also make sure that if there are any cables, external antennas, or cards plugged into it, to remove them during all of that. Best of luck for a resolution.
1helpful
2answers
2010 dodge grand caravan stuck in park with engine on
Check your brake lights, if the system doesn't get a brake lights on signal it will not release park, it is called the park lock system.
There is no reset button on my garmin nuvi 205w?
There is a Reset button on your GPS. On the bottom of your unit is a black label that has your serial number as well as some certification information. If you feel along the left side of the label you will feel an indentation not too far in from the left edge. This is your Reset button. If you have tried cycling your GPS by turning it On and then Off, but you are still having an issue with the unit, you can then depress this Reset button. Do not use anything with too sharp of a point as you can damage the unit by doing so. Use something that has a softer tip and depress the button for about 10 seconds. This should reset your GPS unit to factory default. This means any Favorites you had stored will be lost. Any other data you programmed in, such as gas price, fuel economy, etc., will also be lost.
Thank you for the opportunity to assist you in resolving your issue. Should you need further information or assistance please do not hesitate to let us know.
13helpful
3answers
Garmin nuvi 255 won't turn on
Have you tried doing a hard reset,try using the reset button on the bottom of the gps under the serial label.Or try holding the turn off button for about 10 seconds,good luck.
It just stopped talking. No voice directions, on
Hit the menu buttom, go to settings, then go to volume and see if it is muted. Sounds like the mute or volume down button got inadvertantly hit and turned down or muted. If this does not work, turn the unit over and look under the fold up antenna for a reset button. Depress this button until the unit restarts and should reset the unit back to factory default settings and get you on your way. Good luck!!! If these don't help you, call the garmin support number at :1-800-800-1020. Hope this helps!
1helpful
My streetpilot c330 won"t shut off.
IT'S CALLED A FROZEN SCREEN...
2 OPTIONS
ONE, RESET IT !!! (See resetting instructions below)
TWO, let the battery die out!
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
1helpful
C330 wont turn on or power up
It took a nap...
25helpful
6answers
My Garmin Nuvi 200 wont turn back on
Our Garmin didn't turn on. We unplugged it, pushed the reset button on the bottom and then plugged it in again and it WORKED
Sudden switch off / freezes
Hello, I currently own a Garmin quest myself, and some time ago I had some strange problems myself, I am a electronics technician, and I do have a work around for you. I will explain the problems and a cure for you to try, none of the work arounds depend on any parts to be removed.
1. NO RECEIVING SATELLITE TELEMETRY. I beleieve this could be due to a number of reasons, but more so at sometime corrupted telemetry was the problem to fix this,
a turn GPS on when booted (initialised)
b. depress menu
select settings
select Time Setup
when in Time Setup depress MENU
Select SET DATE
Depress OK button
Depress OK button again on the numberic keypad that appears on the screen (DONE)
what this seems to do is resets the internal date/time clock and the unit starts to work again.
the Second workaround is this but takes hours to perform.
Simply turn the Guest on and allow the battery to fully discharge, usually this works to TOTALLY flush the Memory again, but on my unit I have to setup all the maps again, this is easy to perform, but just takes time. I hope this helps you.
phil
Garmin NUVI 360 GPS Receiver Logo
Top Garmin GPS Experts
Tom Chichester
Steve P
Steve P
Aron
Are you a Garmin GPS Expert? Answer questions, earn points and help others
