Had the same issue. The biggest task was figuring out how to take the TV apart. Two screws at the top, three each on the tires which I gently pried off with a flat screwdriver using the center of the wheel to pry from, two screws that were hidden under the tires and the two screws at the video plugs at the back. Next remove the circuit board by removing the 4 screws. BE EXTREMELY CAREFUL AS HIGH VOLTAGE IS STILL PRESENT WITHOUT BEING PLUGGED IN!. If you do this carefully you wont have to unplug all the plugs. If you do have to remove them mark each one with a colored marker marking the board and the plug. This helps when you have to plug everything back in. Now looking under the back of the board the tall black high Voltage transformer that has the red wire going to the TV tube has really poor solder connections. I found three cracked. I re-soldered all ten of the pins. Plugged everything back in and now it works.
How do you get the tires off on this disney tv.I need to solder the flyback area.thank youHow do you get the tires off on this disney tv.I need to solder the flyback area.thank you
You can't post conmments that contain an email address.
Power supply board have problems,not giving the tv,the right voltage anymore,that why the LED power light indication go off.The power supply board,that the board,where the power a/c plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Tries the tv unplug,replug the tv back an hour later,let the tv reset itself back to factory setting.The tv should work now.Not,than the power supply board is dead.That the board,where the power a/c plug into this board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
poke it open, you'll find bloated capacitors at power supply board. biggest one, with power cord pluged into. replace with thesame value(s).
you good to go!
don't lie, next time! your set has been acting up fpr a while, before it quit. Remembering: few attempts to turn it on, then it works!
good luck.
this is a common problem with psp`s you have what they called "bricked" your psp you can have it unbricked by some one with a pandora battery and a memory card.
My TV/DVD set will not turn on anymore.
