Question about Dell Inspiron 4000 Notebook
My HP dv4000 touchpad scroller is not working. How do I fix it?
Its the small horizontal ridge on the right side of the touch pad. I can move the cursor anyway I want but I can't scroll the page down with the scroller that's on the touchpad.
Posted by dooks_360 on
  • ANDY PLUMB May 11, 2010
    i have the same problem.Dell laptops are rubbish.I use a remote mouse
I have a acer aspire 4738Z laptop. It contains scroller function with touchpad. Touchpad is working normally bt scroller is not working. How to start it again?
Your Touch pad Driver is not install or it is not updated. Download your touch pad driver from Acer Driver Download website and install it. It'll surely solve your problem
Aug 13, 2012 | Acer Computers & Internet
I Have just got my new Dell xps 15 in mail box. Everything seems to work fine accept the scroller on touch pad. Please help me to solve this problem...the scroller on touchpad is not working at all
If the touchpad is working but the scroller isn't then it sounds like a hardware problem. I would call Dell and try to return it for another one.
May 26, 2011 | Dell F3534 Touchpad
I have a dv4000 (dv4272us) and when I'm typing, periodically i must be brushing the touchpad because the cursor moves someplace else and begins typing somewhere else on the document. I using windows 7 and...
You should be able to disable the touchpad from the CONTROL PANEL - MOUSE options.
Go to Control Panel, click Mouse, click the big pointer, click Device Select, look under Touch Pad, click the blank "dot" next to Disable, also checkmark the box next to Disable touchpad.
Click APPLY and OK, then Restart your computer if necessary.
Apr 16, 2011 | HP Pavilion dv4000 Notebook
Touch pad on hp pavilion dv4000 not working. Driver installed touch pad not visable in control panel. How do I re-install.
somewhere on the keyboard there should be a button that disables the touchpad to use an external mouse.you should be able to locate that button.sometimes it will lite up red.
Jan 12, 2011 | HP Pavilion dv4000 Notebook
I dont understand where the scroll zone is on my hp mini. Is it actually on the touch pad, and if so where?
If it is on your touch pad it will be indicated with a small vertical bar, on the right hand side. Slide along that to scroll.
If it doesn't work, then the laptop doesnt have one, and you'll have to use the scroll bar at the side of a web page. (double tap but keep hold on the second tap, this indicates holding down a click) then move up or down as required.
Hope this helps,
Andy
Mar 06, 2010 | HP Pavilion dv4000 Notebook
Touch pad not working
Go to device manager
Right click the touchpad device
Uninstall driver
Reboot system
go here http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-66690-1&lc=en&dlc=en&cc=us&lang=en&os=2093&product=3795289
Reinstall touchpad driver
see if that helps
If you found this solution helpful , please rate my solution below
Kind Regards
1234s282
Jul 01, 2009 | HP Pavilion dv4000 Notebook
Toshiba a300 synaptic touch pad scroller stopped working
Hi there.
The touchpad drivers could be corrupt, try reinstalling the touchpad drivers again.
Go here to Toshiba Support fill in the details of your model laptop and download the synaptics touchpad driver and reinstall it, see if that helps.
http://uk.computers.toshiba-europe.com/innovation/download_drivers_bios.jsp?service=UK
Good luck and thanks for choosing FixYa!!
Jun 01, 2009 | HP Pavilion dv4000 Notebook
Touch pad scrolling problem
Use alps one as well as check weather your touch pad is lock or not
Mar 14, 2009 | HP Pavilion dv4000 Notebook
Touch pad
what laptop is it?
If a dell you can use ALPS software from dells site and you CAN disable the touchpad
Honestly, most laptops you can disable the touchpad in the bios, including Dells.
G'luck
Oct 23, 2008 | HP Pavilion dv4000 Notebook
HP Pavilion dv4000 touchpad problem
Im having the same problem. It didnt start until i had to turn my lap top upside down and such trying to get the battery to work, taking it in and out and so forth.
I push down on the left hand side by the touch pad and it works fine. If i dont press down, my typing will not show, music will not play, the whole pc freezes even the time on it.
Oct 21, 2008 | HP Pavilion dv4000 Notebook
Dell Inspiron 4000 Notebook Logo
608 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
