Question about Toshiba e-Studio 35 Copier
Toshiba E Studio 35 copier goes to power save
It never used to go into ''sleep'' or power save mode but it has started doing it even though is was unused for maybe 5 minuets.
Posted by jmover52 on
Andrew Houle
  • 125 Answers
Hi:
Hold down the 0 and 8 keys while turning on the copier. Keep on holding down the keys until the screen shows a adjustment mode screen. Once it does this key in 205 then you should see a numeric value. Input 15 and press start to lock it in This will change you power saver mode to 60 minutes. Next enter code 206. Key in 19 and press start. This will change your sleep mode to 240 minutes. These are the setting that are most generally used when these copiers are initially set up. Then just turn the copier off and back on. I hope this resolves your problem.
Good Luck
Andrew
Posted on Mar 14, 2009
How do I disable the sleep mode and energy saver on my Toshiba 347cs.... I need the secret code
Do you have a "user tools" button? Press that and scroll to the pertinent screen where you wish to change the information.
Nov 07, 2014 | Toshiba e-STUDIO 347CS Color MFP
Power save mode sleep
Hi Brian,
The printer goes to sleep mode irrespective of what cartridge you have in the printer. Printer goes to sleep mode if the printer is not in use.
Regards,
Sean
Jun 04, 2013 | HP LaserJet 5500 Printer
Toshiba copier service mode.
Only a technician can decipher the Call for Service error.
Jun 18, 2010 | Toshiba e-Studio 35 Copier
My Toshiba e-Studio 35 Copier keeps saying it needs toner, even though I have put in new toner. I must be doing something wrong. Just don't know what. I shook it to redistribute the toner (as directed);...
Generally it takes a while to add toner if you didn't change it when it asked you to. Check your user manual or go online to Toshiba's website and download another one.
Apr 30, 2010 | Toshiba e-Studio 35 Copier
Computer goes to sleep before it even starts up
Hi there, it appears as though the Power Options are set too short a time and the PC is going into sleep mode. Go to Start menu/Control Panel and look for Power options. Set them all to "never" This will prevent her PC from going into sleep mode. Good Luck.
Oct 26, 2009 | Dell Dimension 4600 PC Desktop
We bought a used Toshiba studio 35. The
Hi:
With the copier turned off hold down the 0 and 8 keys together while turning the copier on . Continue holding both those keys down until a function screen comes up. At this point key in 629 and press the Start key. Then press the 7 key and press set. This will disable the Dept code functions. Shut off the machine and power back up.
Good Luck
Andrew
Jun 29, 2009 | Toshiba Office Equipment & Supplies
Error code H2 on screen
Hello sir; H2 code require reset procedure as follow;
1, press "#", "interupt", "c", "interupt" these 4 keys.
2, enter 14 then press start.
3, turn power off and back on .
Jan 28, 2009 | Toshiba e-Studio 161 Copier Copier
Toshiba e-studio 35 Copier Problem
there is one more swith to off the machine.the switch which you are using is only for make the machine into energy saver mode.in that mode machine will be warmed up to take the printouts from computer.
Aug 23, 2007 | Toshiba e-Studio 350 Copier
Changing the Developer on a Toshiba E-Studio28
If you are not a technician I would not even attempt this!
Jun 13, 2007 | Toshiba e-Studio 35 Copier
529 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
jasbo
jasbo
CheckitRight
CheckitRight
digivisionm
Level 1 Expert
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
