I checked the disks I have used on another player and they all worked correctly /
I have tried to c.ean the lens with a cleaning lens disk and it did not solve the problem
It is really a Toshiba DVD Video Player SD2109 not SD 3990
Does not play disc
No disc. -
Load a disc into the tray.
Disc has been
loaded upside down. Place the disc with the label side up.
Disc region
code does not match region code of the player.
Disc type is
not the correct type to play.
Disc is
damaged or dirty. Clean the disc or try another.
Moisture may
be condensed inside the unit. Remove the disc and the leave the
power on for one or two hours.
See the diagram attached.and if the problem persist. Lube the plastic parts with small grease or vaseline very carefully
