Question about Whirlpool Duet GHW9150P Front Load Washer
Green whites? I have noticed a green discoloration to some white and lightly colored clothing - what gives?
Posted by jpitman on
Anonymous
  • 38 Answers
This often is called "lint" but is really a "whiting" left by un-dissolved soap and can be seen at it's worst on dark colored clothes. This is made worse in a colder climate where the cold water entering the washer is much colder than normal. Things that can effect the quality of the finished washed products.
Too much soap: ( we have a test for this further down the page ) If you follow the manufactures instructions on the box, then chances are you ARE using too much soap. They like to sell you their product, I find cutting usage in 1/2 of what the box says will still wash good and also cut your chances of getting "whiting" on your clothes.
Over loading the washer: Even if the agitator is suppose to go back and forth, the clothes are not. If you can hold the lid button on your washer so you can watch the clothes wash, they should 'roll" in the basket and not go back and forth like the agitator. The clothes will go down the side of the agitator, across the bottom of the basket, up the side of the basket and across the top of the water in a rolling motion. Overloading is not just too many clothes but also too little water for the size of the load is another way of having a overloaded wash load.
Water temp is important: Use a thermometer to test the temp of the incoming water in your washer. Hot water should be close to 140 degrees F. Warm water fill should be 100 degrees F. Cold water is approx 60-80 degrees F. What happens in a cold climate location is the cold water temp drops as the outside temps drops, once the water temp gets below 60 degrees F, it can no longer dissolve the soap properly and will most definitely leave "whiting" on the clothes!! Do not use a cold wash, wash your clothes in as warm as poss.  water as they can take. If you have delicates you want to wash in cold, start washer out with warm water as you are putting in the soap and fabric softener and clothes, then switch to cold to let it finish filling up, this will give you a warmer wash but not as cold as straight cold water. I find most washes can be done in a warm wash / cold rinse just fine. If you need ( and probably will ) to adjust your warm water fill, turn on the hot water tap fully, turn off the cold water tap. Let the water start to fill on a warm wash setting. Then slowly turn on the cold tap adding the cold water to the hot water making a warm fill....use a thermometer to set water temp and leave the taps stay when you get about 100 degree F water fill. I adjust my own washer usually twice a year, one on summer time and once in the dead of winter.
Test for too much soap or soap retention: Put in a load of towels or dark clothing that has been bad for the "whiting" problem. These items are bad for holding soap and getting what is called -soap retention-
Wash the load in the warmest poss. water, DO NOT add any soap. Let the washer fill with water and wash for approx. 5 minutes, lift the lid and observe what is on the top of the water. If you see soap and bubbles on top of the water, your clothes have soap retention, this soap came out of your clothes. Let the load finish with out adding any soap and wash all clothes effected with this "whiting" residue. Once all the soap is washed out of the fabric and you start to add some to each load, use about 1/2 of what the box says. Liquid soap has less problems with "whiting" than the powder does, but I find powder soap is better at getting my own personal clothes cleaner.
Posted on Mar 14, 2009
Colors are very off, epecially whites.
if contrast etc not set incorrectly it may be a issue on the main board which processes all signal inside the set===a 37 inch might cost you more to fix than to replace.
Mar 14, 2012 | Dynex DX-LCD37 TV
Wall Plate teminals have the colors of Green, Red, Black, Yellow, White, Blue, Brown and Tan. Cable has the Colors White/Blue, Blue/White, White/Orange, Orange/White, White/Green, Green/White,...
see the table on this link:
http://www.server-servers.com/ge-cat5-network-wall-plate-straight-through-cable-setup/
GE Network Wall Plate Cat5 Ethernet Cable 1 Blue 2 Orange 3 Black 4 Red 5 Green 6 Yellow 7 Brown 8 White White / Orange Orange White / Green Blue White / Blue Green White / Brown Brown
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Apr 15, 2011 | Computers & Internet
I need speaker wire color codes from in dash the colors i have are blue and white gray black tan green and black brown and green white and pink blue and pinik
This should be what you need
Constant 12v+ Wire: Green/Violet
Switched 12v+ Wire: Yellow/Black
Ground Wire: Black/Light Green
Illumination Wire: Light Blue/Red
Antenna Trigger: Orange/Blue
Amp Trigger Wire: Blue (If Equipped)
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Dec 26, 2010 | 1995 Ford Explorer
I need a copy of the wiring diagram/color code for the colby stereo system in a 90-FORD AEROSTAR
90 Ford Aerostar Colby Stereo System
Wiring color code:
Speaker Power Ground
Left Front Orange/light green Light Blue/white
Right front White/light green Dark green/orange
Right Rear Tan/light green Brown/black
Left Rear Tan/white Tan/yellow
Other Wires:
Yellow/black = Hot - Key On
Light green/yellow = Hot - Direct to Battery
Light blue/Red = Radio lights
Black = Ground
Black/light green = Ground
This is what I found for you,hope it helps. Good luck.
Sep 26, 2010 | Car Audio & Video
Have a wiring harness for a CQ-C8100U panasonic CD Player/Head Unit, need a wiring diagram to hook it up to a 2002 Ford Explorer Sport 2 Door
Hello! Since I do not know if your vehicle is equipped with the Standard or Premium System I'll give both sets of wiring...You can identify which system you have by looking at the color of the ground wire...
Red=Standard and Black/Green =Premium
Standard...Constant +12=Green/Yellow...
Switched=Yellow/Black...Ground=Red...
Illumination=Blue/Red...
Standard Speaker
FR + White
FR - Green/Orange
FL + Orange/Green
FL - Light Blue/White
RR + Orange/Red
RR - Black/White
RL + Pink/Green
RL - Pink/Blue
Premium...Only power difference is Ground=Black/Green
Premium Speaker
FR+ White/Red
FR- Brown
FL+ Green
FL- White/Orange
RR+ Purple/White
RR- Blue
RL+ Blue/Black
RL- Yellow
Guru.....saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Feb 18, 2010 | Panasonic CQ-C8100U CD Player
I have samsung DLP TV HL-R5087W with pink/green discoloration
NO ,its not the Lamp it is your Light Engine. Call UED for price of rebuilt one 1-800-648-6657.
Sep 24, 2009 | Samsung HL-R5087W 50" HDTV-Ready...
I want to replace just the 3 wire receptacle head of my clothes dryer. there are three wires in the cord. white, black, green. i unscrewed the head and I dont know where which wire goes.
white and black are power green is ground the ground should be marked on the plug the black and white does not matter as long as the are on the power terminals they are across from each other the ground is by itself at bottom of plug W B
G
Jun 10, 2009 | Whirlpool LER4634J Electric Dryer
No blue color, green replaced blue, white is yellow/green
If the set is hooked up using Component cables (red, green, blue), then check to make sure the cables are hooked up correctly, and not defective (change them out). If the color problem remains, then the problem may be in the Optics block of the television (which is not unheard of in this unit).
If the menu of the TV displays blotchy discoloration, and the discoloring is the same for every input on the tv (stationary), then it is the Optics, and the optics need to be changed. It is not the easiest job in the world, and the block itself is quite expensive, although the unit my be under an extended warranty from Sony. Contact them directly to see if you can get any help (cost or service-wise). Hope this helps...
Dec 29, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
RADIO INSTALLING
there is a code for color!? ok, wait im searching...
found it! here you go, hope it helps...
Wiring color codes are the identification colors that color the wires in your automobile. For example, if you have a British car the blue, blue and white , and blue and red wires are for the headlights. The red and white wires are for the instrument lights, and the green and white and green and red wires are for the turn lights. The color code simply identifies what that wire does. Could you imagine if all of the wires were the same color. You couldn't identify anything in a harness.
Jun 19, 2008 | 2001 Chevrolet Tahoe
Whirlpool Duet GHW9150P Front Load Washer Logo
215 people viewed this question
Marvin
Marvin
Michael Thomas
Michael Thomas
