Question about JVC DR-MV7 DVD Recorder/VCR
Player won't play any disc now
And sometimes won't even register that it has a disc in the machine-for example to put in a cleaning disc
Posted by djmom99 on
  • djmom99 Mar 14, 2009
    I wonder where I would buy a new lens
Anonymous
  • 63 Answers
Time to look inside the dvd player. try readjusting the variable trimmer under the laser lens of the dvd player assembly. It is usually located under the lens assembly. try to adjust the lens at every 1 degree angle up to +/-5deg. sometimes it can be done. if not. time to change for new lens. damage lens is caused by using pirated DVDs or bad disc as the lens is trying to read the data on the cd.
guest.
Posted on Mar 13, 2009
  • Anonymous Mar 14, 2009
    the best place to approach is to find the nearest service center of your dvd. they should have a perfect or compatible replacement for your player. some supplier may offer but you can try.
Why is my Miele Novotronic w1512 saying Drain fault?
I have the same problem, i have cleaned the filter area and there was a plastic sweet wrapper in there also. However, I have put the machine back on an express cycle ans still have the error message coming up?? Drain Fault! I then tried to spin and the spin cycle wasn't working eithet. Whilst the machine was still on i patially undone the filter cap and removed a full tray of water, it then began to spin. What could yhe problem be?
May 21, 2012 | Miele Washing Machines
Luxor tv with dvd player was bought for me from Asda I've had problems with playback of dvds pretty much since I've had it it has a tendency to freeze and not play and on very several occasions it...
Hi Danny.
this could be a couple off things wrong here.
1,could be a faulty dvd player.
2,could do with having a lens cleaning disc put through it.
3,could be a faulty lens reader.
if i was you before i do anything big to it i would run a lens cleaning disc through it and see if it cleans the lens that reads the discs.
if this does not work i would take it back,or get someone to have a look at it for you.
Nov 04, 2017 | Televison & Video
Wii game was stuck halfway in machine kids couldn't get it to go in so they tried to force it till I caught them and stopped it. Pulled it out and when you try to put a disc in there is a grinding...
The best option to fix this problem is to take it to a service center unfortunately, but here are a few question you need to know the answers for to be able to get the best service:
1. Was the Wii on when they tried to force the disc in? If not then the noise could be that the motor mechanism has been jammed and the worm gear for the motor has been stripped. You will need the disc ejector mechanism replaced.
2. Was there another disc in the machine at the time? If there was, it is possible that the first disc has become lodged in the machine and could have been broken into pieces, so when the disc is entered or ejected, sometimes it will go in and sometimes not. When there is vibration the disc pieces or even the whole disc could move in and out of the way of the tray. You would also need to have this removed by a service technician.
Wii consoles are notoriously fiddly to deal with when it comes to repairs, needing special screwdrivers and a keenly trained eye to be able to spot a problem in an extremely confined space.
I'm sorry I could not be of more help but I hope this helps you even a little.
Jul 15, 2011 | Televison & Video
My ps3 is not even registering that there is a disc n the system
Make sure the disc is clean and scratch free. Also, give the laser a clean using a laser cleaning disc. If that doesn't work, you will need to contact Sony for a replacement or get it repaired.
Jul 08, 2009 | Video Game Consoles & Games
WRONG DISC ERROR MESSAGE.
Inside the machine the laser will sometimes adjust itself to a position just out of reach of the disc and you will get a "default message", so it doesn't necessarily mean you have the "wrong disc". This can be adjusted by yourself or take it in to be done. This is only, of course that you have covered the basics and cleaned the discs and inside machine. Just blow in it even, they do attract dust as dvd's are like a magnet to dust.
Aug 23, 2008 | Spectroniq PDV-70X
"No Disc"
"No Disc" also means "I can't read the Disc". The laser must be able to read the disc or you'll get that. There are several reasons:
Bad or noncompatible Disc: Some units won't play certain types of recorded discs. Try a rental or bought DVD.
Dirty laser lens: Either try a cleaning disc, or GENTLY clean the lens with a moistened Q-Tip.
Defective components like laser, spin motor, tracking motor, etc. Usually requires professional servicing.
Hope that helps...
Geno
Mar 25, 2008 | Televison & Video
JVC DR-MV7 DVD Recorder/VCR Logo
Top JVC Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
