I purchased a house that has a craftman 325 wall mounted key pad. The previous owner gave me the pin mumber he thought it was but it did not work. Is there an over ride to set and thenput in my own number?
The step by step programming genie digital remote transmitters with internal set switches.It can be controlled by radio controlled transmitter and by wall mounted key pad.
You will need to purchase a suitable wall mount separately. (You'll need one for LARGE TVs.) On the back of your TV set you'll see there are 4 holes in the lower-central region of the rear panel. They are about 20" apart (left-right) and about 12" apart (up-down) These should match up with the bracket that comes with your wall mount. You will need M8 metric screws that are about 1.25" long. These will also be included with the wall mount. (Which will include some general directions for wall mounting.)
Go to parental controls in system settings.
When it asks 'Change Parental Controls settings?' tap yes.
When it brings up a numeric keypad, tap the center button, "I Forgot".
Next, tap "I Forgot" again. Now you will be shown a screen with a number at the bottom (the 'inquiry number').
Go to: http://wii.marcansoft.com/parental.psp
Enter the 'inquiry number' number in the field marked confirmation
number. Set the current date in your timezone and click get reset code.
And Voila! Your DSi is now parental control free!
RCA which is Thompson is the only likely place and you will need to tell them the model number and do not forget the base may not if available come with the bolts that attach it to the set.
I have just moved into a house that has a supra combination code key safe mounted on a wall outside the back door , it was put there by the first owner who died ,the second owner never used it and don't know the code,I just thought it would be handy to use as we are going away in June to France and its away of leaving a key in case the alarm goes off while away so a neighbour could deactivate it or the police so they don't have to brake down the door or if I get locked out I could have that key for emergencies so is there a way I could find the code for the safe please?
Does it work from wall button? Hit learn button for 10 seconds. Hit again for 1 second and code keypad.Opener lights should blink 2x. Hit learn again for a second and hit button on a remote (Any button you chose). Again, lights should blink. Now should work. Repeat for any other remotes.
You need to press and release the learn botton (don't hold it or you will clear all the codes) If the light bulb(s) on your operator are on the front and/or back, the learn botton is on the back of the operator. If the lights are on the sides of the operator then the learn botton is on the right side (looking from the back of the operator and facing the garage door). After you press the learn button you have about 30 seconds to press in the new 4 digit code in your key pad then hold the enter button until the light on the operator blinks (about 2 seconds). If this does not work check the battery and try it again.
I see I put the wrong number it is a craftman 315 not 325
