Repacled coil pack 6 months ago had the same dionostic code show up again, Replaced coil pack 2nd time the car is still missing and the check engine lite started blinking.
coils, it has just one coil pack. with 3 coils integrated.
its not COPs.
there are many DTCs related, and not posted.
did you try new spark plugs, then new wires. and then only last the coil pack? check compression.
is it failing the same cylinder? (the will fail in pairs, if the pack is bad)
the pack runs 2 cylinders at once (in series)
injectors leaking or clogged.
since you didnt show the symptoms, i cant help much.
how.?
1 month or 1 year?, or how many miles?
answer 1
time, heat,vibration, oil contamination. (pressure washing them)
not using the dielectric grease on the boots.
getting water in the wells over and over, causing flash over , and carbon tracking.
what make you think they are bad.???
my guess, is you see P03xx codes and assume the means bad coil.?
post symptoms.
post scan data, and DTCs.
Hyundia are the best car in the world. Sorry, but they are getting better. I haven't heard of a harness issue. anyway the coils have the ground in common, but the hot wires are separate. probably got there coil packs from china( junk). And I have seen coil packs break down one after the other on different models. Hopefully the dealer is using a better grade of coils. You might even ask them to go ahead and replace the rest of them, seeing there is an issue there. You just never know.
Randy
