TV works OK, but the picture is too green, (white is light green) As there are no controlls inside like in the old days, I wonder if there is a software way to reduce the amount of green
Go into service mode by pressing mute and i button at once on your remote, choose option 2, change green setting by pressing 6 button until color looks natural,save by pressing ok button and leave service mode by pressing i button. good luck knut
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
There are two small holes on the rear side through which you can adjust focus and screen. Use a flash light and locate the two adjustable slots inside the holes. This part carries high voltage. Do not use a metal screwdriver to adjust. Put the TV facing a mirror so you can see how it works. Do not turn more than 1/8th of a turn. The focus control makes picture sharp or fuzzy. Screen control could change brightness. While watching the picture in the mirror, slightly adjust the screen control. Do not turn too much. If it doesn't work, then call a JVC authorized repair center.
Can you switch between tuner and inputs?
If not then you may have a number of problem i.e;input selector or controller i.c.
If you can switch to tuner(cable) and do not get picture then you may want to check your tv cable connection at the back and along the line (splitters) or your tuner may be defective
did the input line still work, for the cable input do an auto search channel to reset your tuner, if it didn't work stop right there your tuner is mabye out
