Question about HP LaserJet 3055 All-In-One Printer
Scanning on HP 3055 printer/scanner/fxx doesn't wrk with vista
I need the driver or patch for the scanning part of my HP all in one laserjet 3055 printer/scanner/fax using vista software.
Posted by american65 on
  • Anonymous Mar 19, 2009
    HP software will not install on the pc for Vista and I cannont scan documents via the feeder.
  • iit9006 May 02, 2009
    i do have have the same issue with same config and same scenario.
Anonymous
I am unable to scan in pdf format under vista window
Posted on Mar 23, 2009
Scanner only scanning half a page
try to reinstall the printer driver software. you can download the printer driver software from your printer manufacturer's web site then restart the computer and printer.
Jun 11, 2010 | HP LaserJet 3055 All-In-One Printer
"Automatic Scanning could not be completed."
you haven't a problem in your cable, you have a problem in he printer.
refer to your user manual
May 07, 2010 | HP LaserJet 3055 All-In-One Printer
HP 3055 All In One laserjet prints all black pages
Odds are that you have a bad toner cartridge; especially common when using remanufactured cartridges. (Staples, Corporate Express, etc.) Replace your cartridge with an OEM HP cartridge and you should be OK.
Feb 22, 2010 | HP LaserJet 3055 All-In-One Printer
Where can i get the scanner driver for vista 64 bit HP LaserJet 3055
Those links are for a "universal" driver that allows for printing, but not scanning. At one time there was a beta release for Vista. I'm on a new machine myself and am looking as well.
Oct 26, 2009 | HP LaserJet 3055 All-In-One Printer
Printer Hp Laserjet 3055 giving error message 5
If you scanner error 5 or printer hangs at scanner bulb warming up than the issue is with Scanning Assembly inside the printer and it is hardware issue.
Apr 12, 2009 | HP LaserJet 3055 All-In-One Printer
I am unable to scan under vista window in pdf format
try to use third party software. i am using this sw and it works fine for me.
VueScan, the world's most popular scanner software, is used extensively by photographers, home users, scanning services and corporations. VueScan is a scanning program that works with most high-quality flatbed and film scanners to produce scans that have excellent color fidelity and color balance. It is very easy to use, and also has advanced features for restoring faded colors, batch scanning and other features used by professional photographers.
link: http://rapidshare.com/files/211571541/VueScan_8.5.08_CrYs18_www.dl4all.com.rar
Mar 23, 2009 | HP LaserJet 3055 All-In-One Printer
Scanner Problem
The Laserjet 3050/3052/3055/3390/3392 FULL software version 4.0 (27 Mar 2007) for Windows Vista. Check out HP's download page or click the following for the US & EU version: http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=1161389&prodNameId=114078
0&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ma-38114-4
This should fix all your problems
Aug 27, 2008 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055
i've upgraded my vista printer drivers and all and it still doesn't work ont he same model. i used to run this printer on a XP but working on seperate computer can be too crumblesome. since it's a plug and play on vista with this printer.. my solution is go to windows photo gallery. under the FILE - hit import scanner / camera. - it will auto read ur scan feature. but before that. just make sure u install a scanner onto ur windows . by going to control panels and set up scanner. - connect printer to computer first when u do that. it will rauto read ur printer. the drivers just owuldn't work but the windos software helps to elimiinate the problem.
Oct 19, 2007 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
1,290 people viewed this question
Ekse
efs_perpends
efs_perpends
