When in Any auto mode or P or A your camera automatically will adjust your shutter speed for ambient light conditions. So if your having issues where your camera is choosing to slow a shutter speed and you photos are coming out blurry then there isn't enough light either because other settings in the camera are limiting light or where ever you are taking photos is poorly lit. Setting your ISO Higher should allow the camera to increase the shutter speed, but will often introduce noise to your photos. The more you play with your camera and learn digital photography the more you'll understand how to make your photos the best they possibly can be. For the time being if getting a no blurr shot is key put your camera in S mode which means shutter priority this will allow you to control and lock your shutter speed and set your ISO to auto this will force the ISO and Aperture to change instead of your shutter speed to get a good photo.
What mode are you shooting in? It seems you may either have your shutter speed set manually to a slow speed or, alternatively you have set your apperture set to a high number e.g f/20 or there abouts. Because this is a very narrow apperture the camera will compensate by using a slow shutter speed. Try some shots in fully automatic mode and see what happens. With a slow shutter speed you can expect any movement to produce blurred images.
-- Are your hands steady as you take the shot, and are you moving the camera before the shutter actually clicks? As a test, put the camera down on a table top and take a picture without moving the camera until well after the shutter clicks. If the resulting image is not blurry--you just proved that your holding technique needs improvement!
--This camera has image stabilization to help you deal with camera shake--do you have this feature turned on in the menu?
--If your subjects are moving and your shutter speed is slow (meaning that the shutter stays open a relatively long time to gather enough light) then you will get blur. And, even if your subject is not moving but the shutter speed is slow, then your camera shake will come back to haunt you.
To fix slow shutter speed, you can either use a flash to freeze the action, or you can manually increase the ISO setting to a higher number, or you can choose a preset like "sports" which will tell the camera you want faster shutter speeds. A higher ISO setting will allow for faster shutter speeds, but it can also result in a grainy look, called "noise" if you set it too high.
Most likely it is your holding technique and the setting you are choosing that is causing the blur. If you are in decently bright light outdoors, you hold your camera steady and wait for the shutter to click, and you have image stabilization on, then you should have sharp pictures. If you are indoors, expect to need a flash.
If you want to use your camera manually. Then you should switch the MODE DIAL button(The top cylinderic button) to M position.
Then, by using the other buttons (firstly use arrow buttons) you may change the shutter speed.
There is no single "best" setting, that's why the camera provides so many. It depends too much on the particular setting, the effect you're going for, and other factors.
If you're seeing undesired movement, that's an indication that the shutter speed is too slow. Using either Manual or Shutter-priority mode, set the shutter speed faster (being careful not to go faster than the maximum sync speed).
You need to press the shutter button half-way and allow the camera to lock in the focus before you press the rest of the way. This eliminates "shutter lag".
Page 41 explains the ISO settings, which seem to be straight forward to me.. The larger the ISO number, the greater sensitivity to light, so the faster shutter speeds you can use (the larger the shutter speed number the faster it is - ie 125 is faster than 60). The drawback of the ISO is that more noise will appear in the images (dark areas look grainy)
To avoid blur, either take your shots on a tripod or ensure that the shutter speed is at least 1/60 of a second
Hey timpo, I would definitely use some kind of remote release since even the smallest amount of camera shake (pressing the shutter button) can cause blurry images in high magnification images. At the type of magnifications usually involved in digiscopeing the depth of field of your images will be greatly reduced and you will need to set the camera to a smaller aperture than usual, which should result in slower shutter speeds. I would definitely have the camera set to manual exposure mode so you can control both the shutter and the aperture although aperture priority should also work well. I would not set the camera to a higher iso since you will lose quality, and since I am assuming you are using a tripod slow shutter speeds should not be an issue. Any movement by the subject will blur the subject if you are using slow shutter speeds so if this becomes an issue you can set the camera to a wider aperture at the loss of depth of field to achieve a faster shutter speed. I hope this helps! Sincerely, Allan Go Ahead. Use Us.
from the manual:
Using Shutter-Priority Mode 1.
Set the mode dial to S (shutter-priority) and a yellow arrowhead on the screen points to the current shutter speed. Press the jog dial and the current shutter speed turns yellow. 2. With the current shutter speed displayed in yellow, rotate the jog dial to select the speed you want to use. 3. Take the picture. If a workable aperture isn?t available for the shutter speed you?ve selected, the shutter speed indicator on the screen flashes when you press the shutter button halfway down. You can use the setting as is, or press the jog dial down to select the shutter speed again and rotate it to select a new shutter speed.
