When I pick up the handset I don't get a dial tone until I push the line key. Then it does not disconnect when I hang up the handset. I have to push the cancel key.
The speaker key just will not work.
Please help!
I agree witht this solution, its a common fault, the admin soultion is to find a differnt headset feature access code!
You have the headset feature active on your phone. You more than likely dialed the headset code inadvertently, there are two ways to turn this feature off. 1) If you have a headset key programed on a key on your phone turn it off. 2) Dial the headset off code, you can obtain this from your local admin.
Sorry I didn't have quick fix for you.
