Question about Music
Repair bellows I have some antique whistling wooden men that need their bellows replaced or repaired. How can I go about this?
Posted by Bill Lynch on
Michial Gueffroy
    President:
  • 1,140 Answers
I would suggest asking an accordian repair technician.
Posted on Apr 23, 2009
Clarinet origin
It would be easier if the instrument was in hand to figure it out.
Your best bet to ID the instrument is to take it to the best woodwind repair man or the largest woodwind selling music store in your area for an opinion. If you do not know of a repair man, contact your nearest AFM Musician's Union to get a referal. To find them check out this link-
Find My Local American Federation of Musicians
Aug 07, 2016 | Music
My Mackie HD1531 has a high pitched whistling sound, all other speakers work fine with the same power connection and desk connection. It whistles regardless of whether it has a sound input or not.
Sounds like a problem with the horn amp in that cabinet. This is not a user fixable problem and needs to go to the shop. Here is a link to the Mackie support page where you can find a link to the repair shop list.
Mackie Tech Support
Feb 19, 2015 | Mackie HD1531 3-Way 15" HD Powered PA...
Wood finish replacement part
If you call 714-522-9000, you can ask them for this part on order or for a distrubator in your area.
Feb 24, 2014 | Yamaha P-155 Electronic Piano
M22 no outgoing, incoming clear as a whistle
Make sure the mute button is NOT showing green. Press once to mute and again to unmute. If the button is working correctly, not stuck or dirty. there may be a loose connection in the microphone wire which means it would have to be taken apart to repair.
Mar 31, 2013 | Plantronics Vista M22 Headset Amplifier
Repair the boton of a violin, need to know what type of gue is used to join the baseto the side.
If you are gluing small pieces of metal to wood, or small pieces of wood to metal, we recommend:LePage's Metal EpoxyJ-B WeldFaststeel Epoxy Putty if you have gaps to fillIf you have a large amount of surface area, we recommend:LePage's Press-Tite Contact (solvent-based)LePage's Press-Tite Green Contact Cement3M Fastbond 30-NFtip.gifClamping can make the difference between success and failure here.tip.gif Whenever you are gluing metal it's a good idea to clean it first with steel wool or sandpaper. (Rust never sleeps.)
Mar 30, 2010 | Maxam Violin
My Fishman Loudbox 100 bass speaker buzzes- what could it be? Someone suggests it could be a poor ground, and to replace the input wire, etc. Does he mean the guitar input cable? The speaker does not sound...
It is a poor ground but it is not necessarily in your amp.
If it is only buzzing when you have a guitar or other piece of equipment connected try a new lead cable.
If it buzzes all of the time......remove the cover at the rear of the amp and remove control panel.
Inspect the feed line to the input. If it is loose or broken....repair or take to have repaired.
Oct 12, 2009 | Fishman Loudbox 100
Music Logo
111 people viewed this question
Top Music Experts
Marvin
Marvin
Are you a Music Expert? Answer questions, earn points and help others
