Computers & Internet Logo
Posted on Mar 13, 2009
How to make a connection with sybase using jtds driver
I am not able to connect with sybase database from my java file
Anonymous
Level 1:
Habit-Forming:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 3 Answers
  • Posted on Apr 07, 2009
Anonymous
Contributor
Level 1:
Habit-Forming:
Welcome Back:
Answers
Questions
0
Helped
2067
Points
5
the first thing you need is the correct JDBC driver, that must be included with your database.
Then you need to create a connection using the driver.
This link could help.
http://www.redmountainsw.com/wordpress/archives/jdbc-connection-urls
regards
Unable Connect To Database
Need more detail in order to help you. Let's start with:
Is this a home or office PC (or Mac, or Linux machine)?
Is the database stored on your machine, or are you connecting to a database server?
What type of database (Oracle, MS Access, Sybase, etc.)?
What type of client / business software are you trying to use to connect to this database?
With that, I may be of some assistance.
2helpful
How to connect two different database in two servers from one ser
you have to get data from the local database store it in the variale and then pass this value to server database connection. hope it will help you
Thanks
2answers
To access data in the database using java
Your question is ambiguously worded. What I believe you are asking is how can you read an MS Access database from a Java program. (If that is not the case, then please re-phrase your question).
Java 1.7 :
Java JDBC: An example to connect MS Access database
Java 1.8 : JDBC: An example to connect MS Access database in Java 8
For other databases,
My SQL database : Java JDBC: An example to connect MySQL database
Oracle database : Java JDBC: An example to connect Oracle database
Source:
Best java training institute in chennai
Best Java Training in Chennai Java training Institute
How can i connect the data base during my project
That seems fine.
I cant assume your level of confidence in programming, however, following are some simple steps you can follow to achieve (for complex implementations, much more time and details will be needed, i can help u with them as well)
1. Create a database in Access ( i assume u r using Access 2003)
2. Create a System DSN (if aren't clear, how to create then goto administrative tools under control panel and you'll find Data Sources (ODBC), here u need to create System level DSN for Access driver (may be Jet 4.0+)
3. In java, you need to import java core libraries for sql (javax.sql package specially)
4. you are almost done, just google for database code in java, simple code will be around 5-10 lines (just for your reference, search with these keywords, ClassName(""), jdbc:odbc:YourDSN)
5. Open a connection using Connection object
6. Fetch the records (select query) using Recordset object
7. You're done.
thanks
Kuldeep
1helpful
2answers
How to connect from jsp login page to database
hey try this code......just found it on the net... Put the code in tomcat and test the application through browser. The browser should display the display the data stored in the table.
Here is the code of our JSP file
<%@ page language="java" import="java.sql.*"%>
<html>
<head><title>Read from mySQL Database</title>
</head>
<body>
<p align="center"><b>Following records are selected from the 'jakartaproject' table.</b><br>&nbsp;</p>
<div align="center" width="85%">
<center>
<table border="1" borderColor="#ffe9bf" cellPadding="0" cellSpacing="0" width="658" height="63">
<tbody>
<td bgColor="#008080" width="47" align="center" height="19"><font color="#ffffff"><b>Sr.
No.</b></font></td>
<td bgColor="#008080" width="107" height="19"><font color="#ffffff"><b>Project</b></font></td>
<td bgColor="#008080" width="224" height="19"><font color="#ffffff"><b>Url
Address</b></font></td>
<td bgColor="#008080" width="270" height="19"><font color="#ffffff"><b>Description
of the project</b></font></td>
String DRIVER = "org.gjt.mm.mysql.Driver";
Class.forName(DRIVER).newInstance();
Connection con=null;
ResultSet rst=null;
Statement stmt=null;
try{
String url="jdbc:mysql://192.168.10.2/tutorial?user=tutorial&password=tutorial";
int i=1;
con=DriverManager.getConnection(url);
stmt=con.createStatement();
rst=stmt.executeQuery("select * from jakartaproject ");
while(rst.next()){
if (i==(i/2)*2){
<tr>
<td bgColor="#ffff98" vAlign="top" width="47" align="center" height="19"><%=i%>.</td>
<td bgColor="#ffff98" vAlign="top" width="107" height="19"><%=rst.getString(2)%></td>
<td bgColor="#ffff98" vAlign="top" width="224" height="19"><a href="<%=rst.getString(3)%>"><%=rst.getString(3)%></a>&nbsp;</td>
<td bgColor="#ffff98" vAlign="top" width="270" height="19"><%=rst.getString(4)%></td>
</tr>
}else{
<tr>
<td bgColor="#ffcc68" vAlign="top" width="47" align="center" height="19"><%=i%>.</td>
<td bgColor="#ffcc68" vAlign="top" width="107" height="19"><%=rst.getString(2)%></td>
<td bgColor="#ffcc68" vAlign="top" width="224" height="19"><a href="<%=rst.getString(3)%>"><%=rst.getString(3)%></a>&nbsp;</td>
<td bgColor="#ffcc68" vAlign="top" width="270" height="19"><%=rst.getString(4)%></td>
</tr>
i++;
rst.close();
stmt.close();
con.close();
}catch(Exception e){
System.out.println(e.getMessage());
</tbody>
</table>
</center>
</div>
</body>
</html>
How to write jdbc connections
http://www.jdbc-tutorial.com/
window.google_render_ad();
welcome_title_image.gif Java JDBC Tutorial Java JDBC Tutorial
The JDBC ( Java Database Connectivity) API defines interfaces and classes for writing database applications in Java by making database connections. Using JDBC you can send SQL, PL/SQL statements to almost any relational database. JDBC is a Java API for executing SQL statements and supports basic SQL functionality. It provides RDBMS access by allowing you to embed SQL inside Java code. Because Java can run on a thin client, applets embedded in Web pages can contain downloadable JDBC code to enable remote database access. You will learn how to create a table, insert values into it, query the table, retrieve results, and update the table with the help of a JDBC Program example.
Although JDBC was designed specifically to provide a Java interface to relational databases, you may find that you need to write Java code to access non-relational databases as well.
JDBC Architecture jdbc.jpg Java application calls the JDBC library. JDBC loads a driver which talks to the database. We can change database engines without changing database code.
JDBC Basics - Java Database Connectivity Steps Before you can create a java jdbc connection to the database, you must first import the
java.sql package.
import java.sql.*; The star ( * ) indicates that all of the classes in the package java.sql are to be imported.
1. Loading a database driver,
In this step of the jdbc connection process, we load the driver class by calling Class.forName() with the Driver class name as an argument. Once loaded, the Driver class creates an instance of itself. A client can connect to Database Server through JDBC Driver. Since most of the Database servers support ODBC driver therefore JDBC-ODBC Bridge driver is commonly used.
The return type of the Class.forName (String ClassName) method is “Class”. Class is a class in
java.lang package.
try { Class.forName(”sun.jdbc.odbc.JdbcOdbcDriver”); //Or any other driver } catch(Exception x){ System.out.println( “Unable to load the driver class!” ); } 2. Creating a oracle jdbc Connection
The JDBC DriverManager class defines objects which can connect Java applications to a JDBC driver. DriverManager is considered the backbone of JDBC architecture. DriverManager class manages the JDBC drivers that are installed on the system. Its getConnection() method is used to establish a connection to a database. It uses a username, password, and a jdbc url to establish a connection to the database and returns a connection object. A jdbc Connection represents a session/connection with a specific database. Within the context of a Connection, SQL, PL/SQL statements are executed and results are returned. An application can have one or more connections with a single database, or it can have many connections with different databases. A Connection object provides metadata i.e. information about the database, tables, and fields. It also contains methods to deal with transactions.
JDBC URL Syntax:: jdbc: <subprotocol>: <subname> JDBC URL Example:: jdbc: <subprotocol>: <subname>•Each driver
I can't connect the ms-sql 2005 database with flex
hi this is jesica am expert to help you to fix this issue for you,kindly call me on +1(518)348-9393 and we will be glad to help you.
1helpful
Hibernate configuration with windows authentication
When you login to your database (download the management tool) right click on server name->properties->security.
There you can choose mixed authentication.
2answers
How to develop a tool for conversion the database from sybase to sqlserver
ahh..sudeep...it is a truly glorious day for this work. The detailed solution is to call Larry Ellison, at Oracle, and enquire if you can have his code.
Top Sybase Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Sybase Computer and Internet Expert? Answer questions, earn points and help others
