With a Crash from my PC, i lost the Driver for my DVD , it's a Aopen DUW1616/ARR but i can't find the driver at the official site, only firmware and that's only an update for the driver you have. My troubleshooter say's, there's no problem but nothing is working and so I can't do anything with it. I tried chancing de regioncode in to netherlands, but can't complete it because it's not installed.
I also lost the backup for all my installed software but for the most of it there was no problem to get it from internetsites, but not for this DVD Player/Burner.
Who can help me to fix this?
The maker is dead, they decided not to support the old products at all not even a nice legacy page, sure silly photos show and zero else.
NO OS told a tall, or PC model , is this VISTA, last person on earth using vista,?
why own relics that have no support at all from anyone but now virus sites, endless website offing virus drivers to the desperate.
2005 made dvd drive, it is 17 years old, and most that old are dead.(nos expected) or needs big time lens cleaning inside.
the driver are 17 years old
and the other good set of driver are from MS but the ended that. leaving a GIANT Sucking sound the vacuum of EOL.
why run Vista 2007 or older, there is no w7 driver but you can try, if you want see if the MS PnP severs can muster up w7 driver, now MS zero support for w7 too.
why not buy a PC or mobo 2010 or newer with i3 , up or h55 up chip set and end all this horror, and run w10
next time post OS and mobo model.
and get 10x better answers. I posted just a 2005 answer.
SOURCE: Aopen DUW1608/ARR Problem
Right click on my computer>properties>device manager>hardware and look for line saying cd/dvd drives and highlight your dvd burner. Right click it and click uninstal. Restart your pc and Windows will automatically re install it. See if this works, if not either needs a lazer clean disc or you need to replace it they are cheap these days.
SOURCE: I downloaded a driver for my DVD AOpen
It is not a driver, it is firmware. Usually firmware has to be installed via a different Application. the OS should recognize your DVD drive/burner without need for a driver.
Testimonial: "Thank you for your answer, it was more than helpfull"
SOURCE: My dvd drive starts and then stops and the light
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or Click on Start, Run, and type regedit and press Enter HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
if this does not fix the problem it might be a registry problem
Close all open programs
Click on the plus signs (+) next to the following folders
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
SOURCE: AOpen DUW1608/ARR firmware flash failed and now it
you will need "flash magic" software, a device to provide 12V power supply to device, one cable to transfer data,download the working firmware for you device and save it to your device.
