Question about iRiver H10 MP3 Player
Files in Iriver H10 not appearing in music.
Hi!
I have just put around 2500 songs on a 20GB iriver H10 and my music files do not appear in the music selection on the first selection of what to do on the iriver (i.e where you choose music, then you can access the artists, songs and playlists etc.). however the files do appear in the browser selection.
i was just wondering if you could let me know how to make the music appear in the music section.
cheers,
megan
Posted by meganschulze on
Anonymous
    Problem Solver:
  • 18 Answers
Try this...
connect your h10 to the pc using the ums trick with the usb connection..
For 20 GB MTP Models
  • Make sure your H10 is turned off and disconnected from the computer.
  • Poke the "reset" button with a paperclip.
  • Turn on the hold switch (so that you don't accidentally turn the H10 on all the way).
  • Plug the H10 into your computer.
  • Turn on the H10 while holding the "O" button.
  • You will see the message "Emergency Connection" if you have done everything correctly. You can now let go of the "O" button.
download and run EASYh10 software (free playlist maker). It will scan the files in your music folder and build/save a playlist to your h10.
disconnect player and give it a try...
Posted on Apr 03, 2009
Iriver won't let me upload from CDs and transfer....
Best way to use the H10 20gb is by creating a directory on your hard drive with your desired mp3 format files. Use ripping and encoding software with your existing audio cds.
Connect the h10 to the PC via the UMS trick (see this website).
Using a file directory on your pc, drag and drop the mp3 files from your pc to the MUSIC file folder on the h10. Install and run the EASY10 playlist creator software on your pc to organize the new files on your iRiver player. Disconnect the USB connection and enjoy!
Mar 22, 2009 | iRiver H10 MP3 Player
Iriver h 10 mp3
OK, one day i turned on mu iriver and it's say's "system file missing to restore the system files connect to H10 to iriver and i dont know how to connect it.The other proplem when playing the music it's like a scratch CD i dont know how to fix it.
Sep 25, 2008 | iRiver H10 MP3 Player
IRiver H10 - System files missing
please, my new iriver h10 is not open. it will say "System files missing"
Aug 03, 2008 | iRiver H10 MP3 Player
Lost h10 iriver installation disk
You can download the software from this site;
http://www.iriver.com.au/iriver/index.cfm?pageID=10001
Probably also from worldwide site. www.iriver.com
As a work-around you can copy files with Explorer to the Music folder and use the Browser on H10 to play them.
Feb 14, 2008 | iRiver H10 MP3 Player
Iriver h10 20 gb
H10 20GB isn't user replaceable. I found a diagram for how to replace it, Mystic River had it. Doesn't look too bad.
Finding a battery though...good luck with that! The downfall of iRiver is that they don't offer replacements. (I don't think, at least)
As for getting music onto your computer from the H10, it's not too difficult. You'll have to go into it from My Computer and whatever drive it's on and then just drag and drop after finding the music files.
Nov 25, 2007 | iRiver H320 MP3 Player
Windows media player vs. h10 20gb
Fimrware upgrade might actually result in this problem - check the iRiver help forums - i believe I saw a horde of people with this issue
Oct 27, 2007 | iRiver H10 MP3 Player
Iriver H10 20gb
iRiver website for drivers
Sep 18, 2007 | iRiver H10 MP3 Player
Iriver H10 20Gb Jammed
Hi StevieB Try following.1/Prepare a handy tool (straightened paper clip) to insert into "reset" hole atop of H10 2/gently insert tool into reset hole and feel a click 3/ turn on H10 if this works great 4/if H10 continues to jam lock up then it may require reloading firmware sounds complicated but easy steps available chk iRiver support website
Mar 28, 2007 | iRiver H10 MP3 Player
IRiver H10 20 GB
Hi Vera I am using windows2000 OS, can not yet justify a faster Pc to run XP .. following is what I use to load and manage my MP3 audio files on my H10 20GB >using an alternative to WMP 10, I use 'EasyH10' .. prepares an H10 player without iriver plus or Windows Media Player 10 based on music and playlist files transferred manually using windows Explorer easyh10-15.exe Info re Easy_H10 URL http://www.misticriver.net/wiki/index.php/Easy_H10 URL http://sourceforge.net/project/showfiles.php?group_id=138812&package_id=152796 download 'easyh10-1.5_win32gui.zip' - connect USB cable between Pc and H10 - place H10 in 'Lock' position - use a tool ( refashioned paper clip ) to press the reset button - start H10 in USB Mass Storage Device Mode... Hold down 'O' button, continue holding 'O' button while you press the 'On / Off ' button until screen displays USB connection, after emergency display - In Windows Explorer locate the ' removable drive' - Transfer your music files with tag information to 'Music' directory on H10 - Run EasyH10 - for Media database construction to display songs in MUSIC mode. - Playlist conversion, a necessary process for your playlist files to become compatible (recognizable) with an H10 player. - EasyH10 also imports/exports tuner presets from/to a text file. Prh
Mar 18, 2007 | iRiver H10 MP3 Player
Iriver H10 20GB
They don't make a battery for the player. My experience with iriver is that they only replace your player with another refurbished one if it's under warranty. Contact iriver.com and go to support, they will help you to a certain point. Sounds like some music files are corrupted, did you download them from Limewire? Lots of nasty stuff out there. Remember your player is a Hard Drive just like your PC and can be damaged by improper disconnect from your PC. Regards, John H.
Feb 07, 2007 | iRiver H10 MP3 Player
iRiver H10 MP3 Player Logo
Top iRiver Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Steven Wander
Steven Wander
Jean Sintulaire
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
