Question about Phil & Teds Kiwi Explorer Jogger
My daughter in law bought a P & T pram on ebay, but it seems to be out of alignment & when we had a better look there seems to be a problem with the wheel..where can we get replacement parts in Western Australia
Hi, if the problem in the front seat just put some lubricant oil on the top after remving the top.
Posted on Mar 17, 2009
The back wheels of my pram seem to slant inwards. starting to get really hard to push pram. please help!
This sounds like your axle washers are bent. I would suggest that you get replacement axles and starlocks. You can usually get these on eBay.
Hope this helps.
May 27, 2011 | Phil & Teds E3 Jogger
Bought second hand oberon pram for my daughter for xmas which is in excellent condition[silver cross],but wheel keeps coming off. I dont think the wheel is the problem as i switched wheels and it still...
There should be a lock ring to hold on the wheels. These wear and fall off or become warped and will not hold on the wheel. What I did was drill a tiny 1/16" hole at the end of the axle. Put on the wheel and put a small cotter pin through the hole.
Good luck and thanks for your question and I hope my suggestions help. Don't forget to rate me.
burdfrenzy
Visit My eBay Store!
http://stores.ebay.com/Pittsburgh-Joes-Pants-Nat
Jan 07, 2011 | Toys
How to replace tyres on a silver cross vintage pram
hi echapman61... here's a link for silver cross where you can email them about thespare part.hope ithelps..please let me know the outcome. thanks for using fixya..goodluck!!
https://www.silvercross.co.uk/contact/spare-parts/
Mar 19, 2009 | Silver Cross Balmoral Pram Carriage...
Navy and white silvercross dolls pram bought 1980 new
I know exactly what you mean about the classic Silver Cross look but if you fit two larger diameter wheels the pram would not sit level unless one of the axles was repositioned to compensate.
Wheels have been retained by a number of methods and then hidden behind a (usually) chrome cap that must be carefully prised off. In more modern times it has become usual to combine the chrome cap with a spring retainer. It is fitted with the gentle tap of a mallet but patience is needed to remove it and no small amount of carefully applied force and even then there is about a 50% breakage. It is possible your pram used these.
Apr 18, 2017 | Baby Gear
Flat Tyre
take the wheel to a pram shop or a bike shop thay should be able repair it
Jan 08, 2008 | Hauck Infinity Standard Stroller
Phil & Teds Kiwi Explorer Jogger Logo
228 people viewed this question
Top Phil & Teds Baby Gear Experts
Marvin
Marvin
Paul Carew
john h
Are you a Phil & Teds Baby Gear Expert? Answer questions, earn points and help others
