Apparently the plastic female part of the fuel line disconnect is subject to cracking. How do you repair this?
SOURCE: how do I replace a fuel line on 2004 bmw 1150rt?
You need to remove both side panels of the bodywork. there are quick disconnects on both fuel lines on the RHS of the machine. These are easily visible once the bodywork is removed. Then remove the glove box from the tank and remove the tank retaining bolt on the RHS of the bike. Disconnect both fuel lines and the electrical connector, and lift the tank off the bike. You will then have easy access to the fuel lines and clamps etc. Since you don't say why you want to replace the fuel lines, it may just be a leak at the quick disconnect which can be fixed with a new O ring.
SOURCE: I have a 2004 BMW
Hello
Try cleaning the plugs first would be my suggestion, if that doesn't do it you may have air getting into the lines or a vacuum leak somewhere. Also it would be a good idea if you can't find it to have the BMW cycle dealer scan the system for fault codes.
The fuel filter is serviced only as part of the left fuel level sensor assembly in the fuel tank
1. Remove rear seat bench
2. Fold carpet forwards
3. Fold back rubber mat
4. Remove the nuts and fold back metal cover
5. Disconnect electrical connector
6. Release and disconnect fuel feed and return lines
CAUTION: The fuel gauge must roughly indicate zero before the left tank opening is opened. Large quantities of fuel may emerge upon opening. If necessary, keep the left tank opening closed and feed an extraction hose through the right service opening to the left tank half and drain the fuel out of the left tank area before proceeding.
7. Release the screw cap
8. Carefully raise fuel level sensor until sensor flange emerges.
CAUTION: Risk of breakage! When raising sensor unit, do not pull excessively on connecting piece of fuel return line.
9. Disconnect line to fuel filter
10. Disconnect suction jet pump from fuel filter (Press catch downwards to detatch suction jet pump)
11. Remove left sensor unit from the tank.
12. Reverse order to install
