Need rear suspension diagrams
Cj92471, it is the crank sensor, had same problem. Replaced mine and no issues.
Your best bet for a diagram is to ask for a suspension printout at your local dealership. Or take a look under any 86-95 Ford Taurus SLO, SHO, or Sable and they use the same design (the SHO just uses slightly different parts. Here is a link though for a SHO parts list with part numbers. Hope this helps.
http://members.bellatlantic.net/~rbruce/SHOParts.htm
SOURCE: Need diagram of 1993 Buick Regal Gran Sport suspension
try www.autozone.com to see if they have your car listed for diagrams pictures and step by step instructions if your car is not listed then try your local library they have all the car manuals and even copy them for you or you can try www.schramauto.com or call them at 1-800-292-1032
SOURCE: Rear suspension froze up. Trying to find a diagram of the suspension
the old elantras and accents have problems with the struts siezing up; especially if the vehicle has been lifted/jacked recently.
i see at least a few elantras/accents at the shop every week with locked up struts, its very very common. i am a hyundai tech, so trust me i see this a lot.
to replace the struts you will need a spring compressor and common hand tools.
check the front struts as well, they all tend to go around the same time, push down on one corner of the car at a time, if the car does not come back up after you release pressure, the strut has siezed/locked up.
DO NOT attempt to replace the struts if you dont have a spring compressor...that spring can really mess your day up if you dont properly compress it before removing that top nut.
SOURCE: where can i get a diagram of a 1995, ford f150 front suspension
You can find it on google under images, or go to autozone.com and register for full free repair manual
SOURCE: 1995 Ford Taurus Sho 3.2 check engine light blink
we don't have info like this, suggest u invest in a repair manual.
