SOURCE: Z force 48 in. cub Cadet mower starts but dies
Check the wires to the seat switch. Under the seat you should find 2 wires connected to the seat. Unplug them, and use a jumper on the end that goes into the body of the mower. Try it again, and if it works, replace your seat.
SOURCE: hydrostat pump leak,cub cadet garden tractor
One... these are pressure relif valves. There are O rings that probably need replacing is all, the valve can go bad but since both are leaking it will probably be just O rings from heat that went bad.
Remove the valves and replace O rings. Use a 'good' pipe thread dope on threads when re-installing.
Two... never use teflon tape on hydralic systems.
Three... boscia is no guro for sure.... lmao
SOURCE: I have a cub cadet lt 1050 mower and I need to
I just replaced mine today and let me tell you it was a pain in the ****, Had to remove the deck, steering attachment on the underside,and the electric PTO. Took about two hours.
SOURCE: mower cuts out
I would check the seat switch first. I had one that did that that ended up being a bad cell in the battery and a faulty charging system. Does it have an amp gauge on it to see if its charging ok?
One other thing....you say that it tries to stay running when you slightly depress the brake...is that including the pto? www.nnyparts.com
SOURCE: The mower deck on our Cub Cadet RZT 50 mower stopped working
You can check the clutch by taking a wire from the ground and a wire from the positive side of the battery and energizing the clutch directly with the belt off to see if thats it. It could simply be a wire loose in the connection on the clutch....their soldered on.
