Lenovo G550-29583AU Notebook Logo
Posted on Oct 31, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
One key recovery wont run on boot!
I cant seem to get onekey to run on boot to restore my computer the button works when windows is running to open up the onekey recovery dash board but doesn't work on boot! is there any other way of accessing this or any other way to restore to factory settings without a disk i did make a restore disk but that has become damaged!
pdxdellguy
Level 2:
  • Expert 195 Answers
  • Posted on Oct 31, 2017
pdxdellguy
Expert
Level 2:
Answers
195
Questions
Helped
24340
Points
442
The "one key recovery" button is to be pressed instead of the power button to turn the computer on. It will then give you an option to boot to recovery.
Marvin
Level 3:
Top Expert:
  • Lenovo Master 85,242 Answers
Marvin
Lenovo Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29058111
Points
266281
Email Lenovo support staff, I thin it is free.
Factory reset for AIO 520 Lenovo
DID IT COME WITH 10 NEW OR 8 ? YES/NO!
is the PC dead,(?)
is windows,,dead?
the answer is 2 answers , this is the toher.
Lenovo OneKey Recovery (OKR)(secret partition) most modern PCs do this, HP, DELL and this pc
the difference is the magic key strokes are NOT the same
that is why we RTM read the manual
I MUST GUESS (TOSS COIN) WINDOWS IS DEAD.
SO....
.aio = all in one
ok, now my first click can work
over 25 sub modes so i pick the 1st in the list guessing
and land here
lenovo made many 520s
https://pcsupport.lenovo.com/pe/en/products/desktops-and-all-in-ones/500-series/aio-520-22iku/f0d5/downloads
AIO 520-22IKU All-in-One (ideacentre) -
I GUESSED DASH 22IKU FOR YOU NEXT
lated Articles
ALL THAT ON YOUR SUPPORT PAGE.
UNDER HOW-TO'S
EVER REPLACE THE HDD
EVER UPDATE THE OS FROM 7 TO ,8 OR TO 10?
what you have there now is anyones guess.
I'd have do hands on.
Windows 8 recovery u330 touch
1 Press the Novo button to start the Lenovo OneKey Recovery system.
2 Click System Recovery. The computer will restart to the recovery environment.
3 Follow the on-screen instructions to restore the system partition to its
original status or to a previously created back-up point.
If Windows cannot be started, follow the steps below to start the Lenovo
OneKey Recovery system:
1 Shut down the computer.
2 Press the Novo button. From Novo Button Menu, select System recovery
and press Enter.
I hhave a toshiba sat and it wont get out of the boot screen. Windows wont load. I dont have a windows cd
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on the hard drive then follow these steps to restore your Toshiba to the Out of the Box condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the system recovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
Need recovery disk for hp mini 2140
Hi
you could try this if it helps
There are two ways to access Roxio BackOn Track to recovery the computer, either through the boot menu, or through the Windows Start menu.
    You can use the boot menu to restore your computer to a previous working state or to return the computer to the state it was in before the last time it was restored.
    1. Press the power button to turn on the HP Mini.
    2. Press and hold down the f6 key to open the Windows Boot Manager, use the down arrow key to select Roxio BackOnTrack , and then press the enter key to open Roxio BackOn Track.
    If you can access Windows, in addition to restoring your computer to a previous working state, you use other options, such as Disaster Recovery.
    1. Click Start , All Programs , Roxio , BackOnTrack , and then BackOnTrack Home to open Roxio BackOn Track
    Hope this helps you
1helpful
2answers
My Lenovo ideapad z565 with Windows 7 does not boot after the Windows logo appears. How can I restore it to it's factory settings by using the onekey recovery (F11)? I already did that but nothing...
For you to perform One Key Recovery, it is done by pressing the OKR button next to power button when the computer is off..(OKR or One key recovery is a very small button usually next/ near the power button that has an inverted U-shaped arrow and usually, some models, the color is orange button)..Select "One key recovery" from the options and next, select "Restore from Initial Back up" after that, you may select "start" to perform OKR..
Just in case OKR button is no longer working, you may ask for the recovery CD's from lenovo to manually install windows.
1helpful
Lenovo Y410, It does not boot. Throws error: There was problem in staring windows due to some error. How do I get to start windows in safe mode?
Welcome to FixYa
It seems that you are having problems booting to windows. There are a number of steps you can try to fix this issue.
1. boot to safe mode. Start tapping F8 right after the computer turns on. This would cause the system to boot to windows advanced boot menu. Once you see the advanced boot menu then just choose safe mode. If you managed to boot to safe mode then you can perform system restore from here. To run system restore just click on start, all programs, system tools, then click on system restore, once system restore has been launced choose a date when the computer was working fine
2. You can also try to boot to windows recovery environment. to do this keep tapping F8 right after the computer turns on. choose the option "repair my computer". The system would now boot to windows recovery environment. From here you can run startup repair and system restore
3. If none of the above steps work then you can use the One Key Recovery feature of a lenovo Y410. Please note that this would reset your computer to its factory image so this would cause you to LOSE DATA on the system. Before you use this feature make sure that you have a back up of all of you data. Note that the computer must be turned off. Press the NOVO button on the computer. refer to the image for its location on your computer
Pressing this button while the computer is off would launch the one key recovery of lenovo. From here you can restore the system to its factory condition.
Hope this helps
2answers
Dear sir, kindly help me my lenovo 450 laptop not starts successfully and displays that one file is missing due to unexpected switch off or reset button pressed and displays that windows could not start...
Start it up in Safe Mode by pressing F8 as it boots up. Normally that will repair the corrupt file. When fully loaded press start and close the laptop.
1helpful
2answers
Laptop format
Just bought Lenovo S10 and so unlucky that window crashed. So have to restore my Lenovo S10 to factory settings. Can’t really find how ot restore to factory settings in Lenovo S10 from the User Manual. So check from google, after many many search, finally found the solution.
For Lenovo S10 to restore to factory settings follow the steps below:-
  • Turn off your Lenovo. (i mean shut down and make sure it’s power off)
  • Now press on the “One Key Recovery” key at the top of your Keyboard, your Lenovo S10 should boot up. Else hold down the “One Key Recovery” key until it boot up.
  • Now you may choose “Restore to factory settings” from the screen and proceed for the restoration.
    ** the restoration will first check if your windows files has been corrupted, if yes, then it will restore it to the original state and no restore is required. else it will continue with the restoration
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
