SOURCE: Goldstar MV154SJ Over the range Microwave oven
check the touch pad , and check the control panel...
SOURCE: do you know what the wattage is of the Goldstar MA-685M Microwave Oven?
600 watts, according to the repair manual.
SOURCE: Goldstar MV1501W not heating or turntable, light/display does wrk
micro switch is bad .remove top vent cover 4 screws,after removing plastic vent panel you will see 1 screw above display time window,remove this screw and lift up the complete button time control panel slightly and pull towards you to remove.there are 2 connections on this panel 1 is a 12 pin connector and a 2 pin power connection remove both put control panel aside.now there are 3 micro switches where the door pins close into the oven lock,remove 2 screws that hold the micro switch housing,on the bottom of housing you will see a small clip gently pull to the right and push back to remove .there are 2 switches on bottom of it and 1 on top. the 1 on top is normally open and closes when door is shut but like mine it stayed open and resulted in (light s display but no turntable)soon as i replaced upper microswitch it runs perfect.i hope this helps .MODEL MV1501W GOLDSTAR
SOURCE: I need a copy of
You can download that here
We're
SOURCE: don`t cook
try opening the case and checking the internal fuses. these normally cause the problem
