It wont print no words or numbers on the page but will print the headline, logo, etc. trying to print out a pay stub and it wont print out any numbers just my name. please help
In this case what i would Request u to do is.........
Goto Control Panel goto Printers folder.........
There u will see the Lexmark Printer Icon...........
Just right click on the Printer Icon and click on Properties.........
Now click on Advanced and goto Print Processor.........
Change it to Lexmark NTEMF 1.0008........
Click on Apply click Ok now try to Print..........
Prints Fine............Issue Resolved........
Same Problem........
Download the Lexmark ToolBar from:
http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_1255995709_0_en,00.html
Restart your computer once and now try to print using the Lexmark Tool Bar..........
It should work fine........
Good Luck..............
SOURCE: Lexmark Z517 wont print black ink
I have a z600 that i use. If not used for about a month the ink does clog the print nozzles and eventually ink cartridge does dry out. To avoid this even if i dont have to print anything I run a diagnostics test that prints out a nozzle aligment test every two weeks.The great thing about this is that it uses very little ink.You can find this test in your software that was provided by Lexmark. This will keep your nozzles cleaned and you will notice this helps extend the life of your cartridge.
SOURCE: LEXMARK X1150 INSTALLATION
Lexmark drivers are here, just choose your operating system:
http://downloads.lexmark.com/cgi-perl/downloads.cgi?lxkprod=Lexmark+X1150
SOURCE: Lexmark X1150 only prints first page
I have an x4550, running windows vista basic on an hp dv6000t notebook. i had the same problem. i contacted online lexmark tech and here's the solution that worked for me, thanks to help from lexmark (transcript of chat):
Please follow the steps given below to change the spool data format:
1. Click on "Start," "Control Panel," "Hardware and Sound" and "Printers."
2. Then, right click on the Lexmark printer icon and left click "Properties."
3. Either on the "Advanced" tab or the "General" tab for some models, there is a "Print Processor" button, left click it.
4. This is the spool format setting. It should be set to the default to "LEMF." Change it to "Lexmark." Under "Default datatype," select "NT EMF 1.008."
5. Click "OK" and exit back out to your desktop.
6. Please try printing again.
SOURCE: Lexmark X1150 driver for that vista computer doesn't print in color
Download the Lexmark X1150 driver at the Lexmark site here:
http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_1019285789_0_en,00.html
Dr.Luiji
