We had a bad lightning storm last night, and now my plasma tv only works on the inputs. When on "air" its just static. One tv got fried(actually smoked) after a close lightning strike. What could be wrong?
SOURCE: no picture or sound, electrical storm
did you ever get it fixed? Are you looking at selling it or need parts. Mine fell and i broke the display panel, but everything else works
SOURCE: 42HDS69-INPUTS
couple of ideas ... on the TV look for the button named input you can change it to the one you cave connected to there .. I am looking up the remote press the TV button then the menu button to move through the on screen input control
SOURCE: 42"HD PLASMA, No sound on Analog input
I think the problem is dry solder joints on the tv. What makes be believe this is you turning it on and off may have been moving the component/s into contact with the board or the act of you turning it off let everything cool down enough to return to their original positions. It now sounds like the contact has broken with the component and the circuit. If you can check for this yourself otherwise find a competant technician. Hope this helps.
SOURCE: Hitachi Plasma TV 55HDT79 that is turning on and off and back on
Go Setup in the menu. At the bottom you will see Reset The Software when power is turned off. Switch this to No.
Got it fixed
