SanDisk 1GB microSD Memory Card Logo
Question about SanDisk 1GB microSD Memory Card
My microSD Memory card gives Unsupported file error on mp3 music
All MP3 sounds say Unsupported format
Posted by Ngong Kenneth on
5 Related Answers
SOURCE: my microSD card memory is
HI there,
It seems that your memory card is infected with the virus which restricts you from formatting,
To Format the memory card:
Take out the card from the cellphone, Insert your memory card in the card Reader, (External more preferably or internal memory card if you are using laptop),
When window recognize that memory card is inserted , Just hit cancel and do not open your Memory card.
Right click on my computer and select Manage Then Select Disk Management it will show you the list of installed Hard Drive, DVD , and memory cards, right click and select your memory card (On the left size you can see the size of the memory card) and select Format, a pop up screen will come and you can select format options. Select Perform a Quick Format. and then click OK, it will format your memory card, and all the data will be erased from the memory card,
Caution: Always select the right partition in Disk Management for formatting to avoid any possible data loss,
If you require more assistance, feel free to reply to this post
Regards-BA
Posted on Jan 16, 2011
Anonymous
  • 75 Answers
SOURCE: MicroSD wont work in MP3 player
mp3 player wont recognize videos....jus mp4 will do it if the video is in mp4 format
Posted on Sep 23, 2008
Anonymous
  • 96 Answers
SOURCE: Error Formating Sandisk 2GB microSD Memory Card
It needed antivirus in ur pc or mobile so u can check there is any virus in ur memory card
Just like formating when u attach it to pc right click mouse button, it shows scan with ....... ur antivirus's name , click on it which starts scanning for virus or if u have any antivrus in mobiles just select that icon & start scaaning for virus
There are some of antivirus product available on net u can serach & download it free
Regards
Sandesh
Let me know ur comment on this solution
Posted on Feb 28, 2009
Anonymous
  • 198 Answers
SOURCE: Transferring music files to microSD card
It says on the manual this this phone accepts microSD™
memory cards up to 2 GB (depending on memory
card manufacturer and type). Check with your phone manufacturer if there are known issues with a particular memory card brand.
Also, try connecting the memory card to your computer via memory card reader and see if the card will be detected. That way, you can check whether the card is working or not. Save the music files from the PC to the memory card, then see if the music files will appear when you insert the card to your phone.
Posted on Jun 24, 2009
Anonymous
  • 724 Answers
SOURCE: When I Go To Music Player with the memory card in
did it ever work or is it a new idea of having a hugh memory bank the SDHC will not read with old tech stuff 2 gig SD is at best
Posted on Aug 01, 2009
Sony ericsson w302 unsupported format
You could just play the music from the phone memory, off a computer or on a normal mp3 player such as an ipod?
2helpful
The Music and Videos and pic das not work well on my MicroSD 1GB on my phone but some work and same sayes Unsupported file and it is mp3 Music.
I'm sorry to say, but it sounds like the MP3 files in question aren't supported by your phone, and not the Memory card. They may be corrupt files, or an unsupported version of the file.
Corrupt files can be checked by attempting to open them on another device or on your PC.
I wish it were easier to explain, but with MP3 files there are different Bit Rates - these are the speeds of how much music is there. The higher the bit rate the better the quality of the music. Some devices aren't compatible with really high bit rates. The lower the bit rate, the smaller the file size, but you lose quality with such files.
If you can play these files on your PC, I would check to see what the bit rate is on them. You may be able to see this by right clicking on the file and see the properties. You may have to view this from within your audio player - Windows Media Player or iTunes.
Compare this to a file that you know plays on your phone. See the difference? I believe this file will be at a lower bit rate.
I'm not sure how you would convert them to a lower rate. But if you've "ripped" them from a CD, then re-rip them and select a lower rate.
Also some phones or Music players (MP3 players) can only play MP3 files. It may be possible the file is an WMA file instead. This is another format altogether, and your computer may be able to play it, but your device might not.
There's a give and take with MP3 files as you can see.
I hope this is helpful.
Mark
How do i delete JUST the music off of my SD memory card?
Your music is likely to be in one of two formats. .mp3 or .wma you can search on those tow formats or view them in windows explorer and simply delete those files. It will leave everything else in tact.
Unable to Play Music & microSDHC Card
Unfortunately, you can't use a microSDHC card in the TH1101. The TH1101 was designed to work with microSD cards. The microSDHC is a newer standard; while those cards will fit into the slot, they will not function properly in microSD devices. You'll have to limit yourself to microSD cards 2GB and smaller.
Trying to use Micro SD memory card to put music on my phone. I can see the song titles but get an "Invalid File" message when I try to play music.
You probably need to convert the songs to mp3 format to play on your phone. What model phone and what music format are the songs (what are the last 3 letters of the song name, the file extension?)
How do you download music from our computer to the
It is hard to provide any useful suggestions without knowing the type of cell phone your son is using.
Normally he would put the memory card in the cell phone microSD slot (provided it can support 2gb card), plug the USB cable from computer to cell phone (if it supports this). Normally the phone will have also got some software apps CD which should be loaded to computer. This will provide the necessary functions to load music files to the phone.
Alternative to USB is bluetooth connection which both the computer and the cell phone will have to support. He can transfer music files that way.
I am not sure if he can copy the files directly from the computer to the memory card and play it on the cell phone as data formats are not standard. Also iTunes files need to converted to mp3 format. If these are protected iTunes files then it becomes a bit harder - best to burn a CD and then rip into mp3 format.
Once again these suggestions are useless if cell phone cannot play music (mp3 or WMA etc) files, does not have microSD slot, does not have USB or bluetooth support.
9helpful
2answers
EnV2 does not recognize MP3 files on micro SD card
This was tricky, but I was able to get MP3 files recognized on my daugter's phone.
First, the MicroSD card needs to be formatted by the phone. The phone requres a special directory structure to be created. You may be able to do this manually, but I did it by letting the phone initialize the card. To do this, insert the MicroSD card. Make sure you push it all the way in.
Go to Menu 9 Settings and Tools. Then menu 9 Memory. Then menu 3 Card Memory. The phone should recognize the card and initialize it by creating the special directories for My Music, My Videos, My Sounds, etc.
Then put the card into your PC and copy your MP3 files to the My Music directory on the card. I could not get the phone to recognize sub folders, so make sure you copy everything directly to the My Music directory and not the one under it.
Now the card is ready, you have to tell the phone to use your card memory and not its internal memory for these items. Go to Menu 9 Settings and Tools. Then menu 9 Memory. Then menu 1 Save Options. Pick Pictures, Video, and Sounds and set the phone to use Card memory for each.
Now you can import the music into the music player on the phone. Go to menu 5 Media Center. Menu 1 Music & tones. Menu 4 My Music. The music player should then Import yhour music into the player and it should now be playable.
(I think these accurately reflect what I did)
You can also go to 9 Settings, 9 Memory, 3 Card Memory, 4 My Music to view your music.
Jan 01, 2009 • Cell Phones
Error transfering mp3 files
j'ai un ipod de 1G elle a des vuris elle m'ècriè erreure format dans le 19eme chançon puis elle redemare merçi bcp de votres aides
3answers
Transferring audio(music) to microSD card for Nextel i870 phone
Is the format of the files correct the phone probably only reads mp3 files so the files you copy to the phone must end in .mp3 not wma.
Top SanDisk Electronics - Others Experts
Marvin
Marvin
W.L.
Mike
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
