Question about Microsoft Windows 7 Home Premium Operating System
WINDOWS VISTA 64 bit not reading CD Rom/ DVD player after services pack download. Driver is best. Error message "problen in registry (code 19)
Posted by pherbert2729 on
mikadot
  • 2,113 Answers
If it truly needs a driver then install patin-couffin It will bypass all that windows uses now and accurately talk between drives and the dvd-rom. But it sounds to me that your dvd-rom just failed. You never know when they are going to go
Posted on Nov 30, 2013
  • mikadot
    mikadot Nov 30, 2013
    If there are registry problems windows could be just damaged and needs either an update again or a reinstall to fix
5 Related Answers
meshif
Mike
  • 81 Answers
SOURCE: where to download windows vista ultimate 64 bit
heh if your looking for a free download I would assume that's against the FixYa ToS. I would suggest calling Microsoft or going to a local electronics retailer and Purchase a legit copy of the OS. Software developers are people too. They need to eat and have families just like you and I.
Posted on Jan 24, 2009
Anonymous
  • 62 Answers
SOURCE: microsoft windows xp home edition version 2002
looks like 32 bit to me. it is rare to see a 64 bit version of windows XP.
Posted on May 11, 2009
Anonymous
  • 10406 Answers
SOURCE: Optiarc cd-rw crx880a ata device: This device cannot start. (Code 10)
Did you try to click "Troubleshoot" on the page that reported "cannot start" ?
Did you try to click on the device, and choose "uninstall" ?
Then, rebooting Windows should cause Windows to "find new hardware", and properly configure the DVD/CD drive.
Posted on Dec 03, 2009
krishdkiller
Krishnendu Sarkar
  • 384 Answers
SOURCE: How to play DVD RIP file on windows media player
download and install win7 codec pack (free) .
then you will be able to play
Posted on Jan 01, 2011
Riztech
Mohammed Rizwan
  • 731 Answers
SOURCE: Attempted to install service pack 3 but received error message: C:\windows\system32\drivers\acpi\sys.
Hi Michelle,
This problem happens if you run "Alcohol 120%" and "DAEMON Tools" applications. If you don't have these apps installed follow the below step to fix this issue.
  1. Go google "Unlocker Assistance" and download the software (or the link is provided below), it's free and very useful program. This program can unlock or kill or delete any files that's being used, no matter what situation the file is on, it can unlock the file or kill the process which is using it. (The icon looks like a star magic wand, that's the right program)
    Download the software below if you have trouble finding it. http://www.techspot.com/downloads/1029-unlocker.html
  2. After you install the program, then go in your My Computer, and right click on the C:\ and click on Search. Then find the keyword "atapi.sys" that the error message mentioned. You will see an icon that looks like a white sheet of paper, right click on that and choose "Unlocker" on the menu. I don't know if this would show up by default, but it should. After that a window should pop up showing you which program is currently using the file, I think it was "System". Now you need to click either on the "Unlock" or "Unlock All".
  3. After that, the "atapi.sys" file should be unlocked. Now, go back to the error message and you should see "Retry" or something like that, then just click on that. Viola, the process will continue on.
Posted on Feb 08, 2012
I have a creative webcam , i lost the cd software and i need toinstall it now. i run windows 7
You can download the latest driver from their site here:
http://support.creative.com/Products/Products.aspx?catid=218
Just select your model there and there will be a download link on the product page. If your model is not listed there, scroll all the way to the bottom and click on "If your product is not listed above, please click here."
Mar 04, 2011 | Creative Labs Live! Cam Notebook Pro...
Says my system does not meet requirements . Cannot download . Running Windows Vista with Service Pack 1
You need to install Vista Service Pack 2 Minimum System Requirements:
  • Microsoft® Windows 7 Home Premium (32- or 64-bit), Microsoft® Windows Vista™ Home Basic SP2, Windows® XP SP3 (32-bit) or SP2 (64-bit), 1 GHz processor and 512 MB RAM
  • 1024x768 DirectX 9.0c compatible graphics card with at least 16-bit color setting, sound card, DVD-ROM drive
  • 2 GB free hard drive space for installation
  • Windows Media Player 10 or higher
  • CD Writer for audio CD and DVD Writer for DVD
  • Internet Explorer 7 and 8
  • QuickTime player version 7.6 for some functionality
  • One available USB 2.0 port
Mar 01, 2011 | Roxio Easy VHS to DVD for PC
Code 19- philips cdrw/cvd scb5265 ata device how do i fix it
Do you receive the following error message?
Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. To fix this problem you can first try running a Troubleshooting Wizard. If that does not work, you should uninstall and then reinstall the hardware device. (Code 19)
Code 19 is a common error message, your computer sends because NERO, Roxio, and similar CD/DVD recording software and also and update for Windows VISTA (KB938194) is causing issues. It can create problems with your sound as well.
Even if you uninstall these it will not resolve the issue, because these programs leave the problem inside your registry.
What is happening to your computer?
Device Manager sees the drive, but you get the yellow exclamation mark and it indicates "Your registry might be corrupted. (Code 19)"
How most people try to fix this error – and you are probably doing the same - without any luck…
If you try to uninstall the device and the driver and read new hardware - no change.
You can try to update the driver and the wizard will say there is no better driver found for the hardware.
You can try to run the install CD (copied it to a flash card and ran it from a flash card reader since you can't run it on the DVD drive) - same problem will occur.
You can't do a repair install of Windows since it is on CD and it won't boot properly from the drive.
You can try to use an external DVD writer (HP dc5000) through the USB port and it will get the same code19 error.
Even if you try manually copy the drivers listed in driver details for the device - no luck
Jun 14, 2010 | Samsung Philips CD-RW Kit 4x4x32 ( CDRW...
I have a emachine T3646 and the cd drive will not work. I get the error code 10 in device mgr Device can not start. I tried to download new software but get an error message saying the software was found...
try this one:
if you are using windows XP
- click start
- click run, in the run type in regedit
you will see a registry editor window
in the registry editor window
- click the + sign at the hkey_local_machine
- click the + sign of system
- click the + sign of currentcontrolset
- click the + sign of control
- click the + sign of class
there will be bunch of random letters and number under that control
try to find this one
{4D36E965-E325-11CE-BFC1-08002BE10318}
if you click this check if you will be able to see DVD rom at the right side of the registry editor window
you must delete the upper and lower filters
after that restart the computer and try to put in dvds
for vista or win7
- click start and type in the start search regedit
after this just do the same thing with the win xp instructions
if still doesnt work try to uninstall/reinstall the cd/dvd driver
try also to update the DVD codec. you can also try to download the most updated windows media player, power DVD or any software/program that have dvd codecs or that acts like a player for DVD
i hope this works.
Feb 25, 2010 | E-Machines emachines (emachinees) CD-ROM...
Code19 on sony cdrwdvd willnot reconize on inspiron 1525
Your CD drive or DVD drive is missing or not recognized by Windows or other programs, so you cannot play or access a CD or DVD. This issue might have occurred after you installed, uninstalled, or updated a program or Windows Vista.
This issue may have occurred after one of the following situations:
  • You upgrade a computer to Windows Vista or install Windows Vista Service Pack 1.
  • You install or uninstall CD or DVD recording programs.
  • You uninstall Microsoft Digital Image.
You may see one of the following error messages:
  • One of the following error messages appears when you view the CD drive or the DVD drive in Device Manager.
    Error message 1 The device is not working properly because Windows cannot load the drivers required for this device (Code 31). Error message 2 A driver for this device was not required, and has been disabled (Code 32 or Code 31). Error message 3 Your registry might be corrupted. (Code 19)
  • An "error code 39" error message.
  • A message that resembles the following appears in the notification area: Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41)
  • you can find this information and more at this site..
  • http://support.microsoft.com/kb/314060
Nov 08, 2009 | Dell OptiPlex GX260 PC Desktop
Dvd rom not reading, can't find it in My Computer
download REGcure from the net and istall it on your computer. run it and it will tell you where to find that code and delete it.
alternatively, since you do not have the disc anymore, find someone with the same windowa version though they would have different product keys. for vista, run upgrade so that you will not loose your data and the windows will be replaced with new registry. for XP, run the set up configuration as if you istall a fresh copy, after accepting the terms by microsoft, there would be options there to install a fresh copy or to recover the existing. press R to recover and wait for the next prompts. on this too, you will not loose your data because you not formatting but replacing the window with a new registry to help your computer to use all its hardwares efficiently withour errors.
bring feedback if possible.
thanks,
wonder
Sep 18, 2009 | Dell Inspiron 530s Desktop Computer...
Canon MP500 all in one printer is not compatible with Windows Vista. Is there a solution for this problem, or do I need to buy a different printer?
My Canon PIXMA MP500, purchased in mid-2006, came with the (then) ScanSoft OmniPage SE2 software on a CD. The PC had WinXP Installed. I had no use for the ScanSoft it so I made no effort to install it.
Fast Forward:
Two PC crashes later, July 2009. Using Win Vista Home Premium
LOST, important WinWord document file, only a hard copy available.
I tried to recover, scanning the "Xerox" copy. The SE Version of OmniPage was very complicated but I succeeded in producing a replacement *.doc file.
It appears that newer editions of WinVista contain the right printer drivers for this Canon Model.
Apr 26, 2009 | Canon Pixma MP500 All-In-One InkJet...
Vista Ultimate disabled my Blu Ray DVD Player
How to fix Code 39 error
with DVD/CD-ROM drives in Windows XP or Vista
I was fixing a computer the other day and ran across the following error in Device Manager on the CD-ROM drive.
"Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)"
Because of this error, the drive did not show up in My Computer and the customer was unable to burn CDs or read any CDs.
I uninstalled the drive from Device Manager, rebooted the computer, and the problem remained, so obviously it appeared to be a registry issue that I would have to solve. If you are receiving this Code 39 error and your CD or DVD drive is missing and has a yellow exclamation mark in Device Manager, I hope this information is useful.
To solve this Code 39 error, follow these instructions:
NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Another possible CD/DVD issue you may want to investigate
http://www.pchell.com/support/copytocd.shtml
Microsoft surprised more than a few people on Thursday when one of its developers told a technical crowd in Australia that 32-bit versions of Windows Vista won't be able to play back next-generation high-definition protected content, i.e. commercial Blu-ray and HD DVD discs.
Later Thursday, representatives in the U.S. said that senior program manager Steve Riley was mistaken.
"The information he provided to that audience was incorrect," a representative told CNET News.com. "Playback is possible with Windows Vista in 32-bit."
The decision of whether to offer that support, the representative said, won't be made by Microsoft but rather by the third-party software makers that create DVD playback software, folks like CyberLink and InterVideo.
"It is up to the ISVs providing playback solutions to determine whether the intended playback environment, including environments with a 32-bit CPU, meets the performance requirements to allow high-definition playback while supporting the guidelines set forth by the content owners," Microsoft PR manager Adam Anderson said in a statement. "No version of Windows Vista will make a determination as to whether any given piece of content should play back or not."
Oct 02, 2008 | Microsoft Windows Vista Ultimate Edition
Code 19 and SD R2102 CD-RW/DVD-ROM Burner
Code 19 Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged.
This can occur when more than one service is defined for a device, if there is a failure opening the service subkey, or if the driver name cannot be obtained from the service subkey.
Recommended Solution :
Many third-party programs that control CD or DVD burning (as well as some player applications) install CD- or DVD-ROM filter device drivers into Windows. These filter drivers are meant to allow for low-level hooks into the hardware, to allow for functions such as packet writing (where a CD-R/W or DVD-/+RW can be written incrementally, like a hard disk).
These filter drivers sometimes have problems that can cause the CD or DVD drive to stop working correctly. The device entry for the CD or DVD drive in the Device Manager may show up with an error descriptor that reads "The device could not start." Additionally, there may be an error message that reads "One of the filter drivers for this device is invalid." The devices themselves do not show up in Explorer. Error codes for the device include code 31, code 32, code 19 or code 39, and sometimes the even more ominous warning "Your registry might be corrupted" appears.
Fixing the problem simply involves deleting the filter entries for the third-party device drivers. These entries can sometimes become damaged (which is what produces the "corrupt registry" warning).
To delete the offending keys, open the Registry and navigate to HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlCl ***\{4D36E965-E325-11CE-BFC1-08002BE10318}. . Delete the keys named UpperFilters and LowerFilters and reboot.
Several of the products made by Roxio are infamous for causing this problem, although in fairness to the company the most recent versions of their Roxio CD/DVD writing software (6.2 and higher) do not have these problems. Users of 5.0 or 6.0 editions of the Easy CD & DVD Creator product, which has been bundled with many new PCs in the past, should upgrade to 6.2 or better. Other programs can also cause this problem, with the same solution.
Note that after you do this, you may lose functionality in the program that uses the filter drivers, which may need to be reinstalled.
It will be highly appreciated if you could take a minute and provide us your feedback..
May 14, 2008 | Toshiba SD R2102 CD-RW/DVD-ROM Burner
Microsoft Windows 7 Home Premium Operating System Logo
Top Microsoft Computers & Internet Experts
efs_perpends
efs_perpends
k24674
Jax Planet
Jax Planet
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
