Question about Haier Refrigerators
Haier CFL-CFE f/f is very noisy
Our fridge/freeze has periods of 10/15 mins at least 3 times a day when it is very noisy and the noise is getting worse, can be heard upstairs. Otherwise it works. Any advise. Based in Dublin Ireland and still under warranty but who are the Haier agents in Dublin, as we can't find them now?
Posted by Orlaith Hartnett on
geob91
    Passionate:
    Visited the website for 10 consecutive days.
  • 128 Answers
Intermittent noise is usually a sign that it is not flat/ on an unstable floor. The truth of the matter is that all appliances today are built cheaper as time goes on and that makes funny things happen including noise.
The fact that it is not happening all the time tells me that it is not a mechanical failure. IE: if a motor goes bad,it stays bad and does not have mood swings 3 times a day!
Easy fix.. When it starts making noise,just put your hand on the side of it and gently push. If it gets softer/goes away then you need to shim a corner or adjust the feet (most delivery guys drop it and leave. They do not adjust feet/ doors/ or anything. They just deliver) You can try different parts until you get it right but the hard part is being there when it happens
Posted on Feb 03, 2018
5 Related Answers
Jose Ramirez
  • 263 Answers
SOURCE: FREEZER SOUNDS VERY NOISY
that because the internal fan is hiting the ice or has bad bushings you can hear the noise just with the door close because when you open the door there is a switch the one turns off the internal fan so when you close the door it turn on the fan again if you wants to hear that with the door open just open the door and push the botton swich with your fingers and you'll hear the noise
Posted on Dec 29, 2007
Anonymous
SOURCE: Dreambox 500 c keys
Go to DBFN.TV You may have to sign up for a new account for the website. In there you will find the most up to date fixits and keys, downloads, programs, updates. hope this helps
Jason
Posted on Oct 15, 2008
Anonymous
SOURCE: need codes for ntl eurovox dublin ireland
Codes working on 08/06/2009
5401
b0 b8 4f 04 e6 5f 87 80
a3 eb ec 07 d6 49 d2 eb ...
Posted on Jun 08, 2009
Anonymous
  • 81 Answers
SOURCE: Noisy indoor air conditioning units
Ok. So first things first. LG have a reputation with all their products. THEY ARE ALL BAD! If you remember GoldStar, they are now LG. GoldStar had horrible products. Now this is what LG has. The fact that the filters are cleaned and the units are serviced is an abosulte plus and will provide the units with extra longevity. Now are these drains are they used for water drainage. If so the upstairs units shouldn't need them unless there is some sort of rise in the drain pipe.
Now to the noise. It seems like there is something which is causing the fan to make a noise. It could be loose bearing or a piece of the fan which has broken away causing it to hit the inside of the unit. Since it is on both units, it would be a generic problem with this series and unfortunately is what you are stuck with now.
To combat this problem, I would: ring LG and the company who installed them and demand that they be repaired and have a warranty on the repairs. Just a heads up, LG are really bad to contact should you have a complaint, so keep persisting that they be repaired free of charge since that they are still under warranty.
If you are not happy with LG or your installers response, I would remove the units and have another brand put in. I recommend Mitsubishi Heavy Industries and Panasonic. Both units are whisper quiet. In fact they are quieter that the LG.
Oh and that only reason why LG boast about their "whisper quiet-ness" is because that is probably the only good going for them - and thats' not even right!
I hope that I have helped you in some way. Good Luck!
Mat
Posted on Jul 16, 2009
Anonymous
SOURCE: samsung refrigerator freezer not freezing
I just returned the same fridge to Lowe's where I bought it using the warranty for the same problem. The temperature sensors went out, and everyone said the computer board needed to be replaced but no one could seem to get it together enough to order us one. Month later we are getting a new fridge.
Posted on Jul 28, 2009
Our fridge is freezing everything, we tried to turn up the temp with no success
most likely a problem thermostat
call a technician
check your warranty period as it may be still under warranty
Sep 24, 2016 | Haier Refrigerators
MY HAIER 1.7 FRIDGE FREEZES ONLY
my trf 285 intergrated fridge freezer has same problem fridge is freezing our food have been informed that a valvue is stuck open the solution
offered was defrost and leave for 2 days i did that it did not work the valvue is not replaceable hope this is some help
Jan 21, 2013 | Haier Refrigerators
Noisy and fridge not cold
well i rember that guy??? that was when i had hair!!!!!!!!!!! sadly its gone now? along with my "get up and go" that got up and went!!!
your fridge,,, come on now,,its 10 years old,, dont you think you have had your moneys worth out of it yet?,,it needs a re-gas, pricy job that is, also maybe a thermostat as well,,,do yourself a faver dont spend money on it, its well past it,,bit like me now! save your cash and get a nice new fridge,,,just so you can show it off to all your palls,,, the old Dr who???happy days "A"?
May 05, 2010 | Fisher and Paykel Active Smart E522B...
Noisy Fridge !!
is the fridge on a level and solid surface ?? hope this helps regards Jim
May 10, 2009 | Refrigerators
Maytag msd2456dew not cooling / not freezing after noisy fan
my Matytag msd2456dew fridge fan is running, no ice bulid up on coils in freezer section, but no cold air to freeze anything in freezer section or cold air in fridge section. what can be the problem?
Sham
Feb 15, 2009 | Maytag Refrigerators
Fridge Freezer very noisy!
cycling every 30 mins is normal. bear in mind that frost free are more noisy as there are fans running as well.
you appear to have temp in freezer too high - should be -18degC
Oct 11, 2008 | Freezers
Fan is a big issue. New problem though.
good day!first and foremost, in most freezers, the highest freezing point is 7.in regards with the water dripping from the air vent hole, you have to minimize your your freezing setting to the middle.turn it to 3 or 4 freezing point.
Aug 22, 2008 | Haier HTE21WAAWW Top Freezer Refrigerator
It's spitting ice crystals when turned on, and is very noisy.
I'm in a similar situation with a physical neccessity for a/c, year round, even though I live in temperate New Jersey. My husband is an A/C / Refrigeration tech & here's some things you can try to fix your Haier A/C.
1.) Make sure you keep the area where the filter is clean, if you aren't using a filter, you are clogging the air flow much quicker, which can lead to freeze ups.
2.) Due to how shoddy things are made now-a-days & with the storm coming through, you may have a conked out compressor or may have a small refrigeration leak, which can also cause freeze ups.
3.) Make darned sure that the unit is level, if you find it is not, leave your unit off for at least 24 hours for the refrigeration gas & oil in the system to level off.
Sadly, I do not know the model or type of Haier A/C you have & as I'd mentioned, things are no longer made to last like they once were & to get 3 years from a newer model is likely to be the best you can hope for. Haier is fairly decent with wanting to keep up customer morale & if it's a newer unit (younger than 18 months), they may help you to repair it for free or low cost. Good luck with that!
Aug 06, 2008 | Haier HPAC99ER Air Conditioner
Fridge makes howling noise
Hi there!
Check at the back for any objects or packets that are in contact with a fan. This often causes unusual noises.
See if you can identify the source of the noise, ao I can help further.
Thanks.
Jun 21, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Fridge making loud snapping noises
we have much the same problem except ours was going on for some hours at a time and then off for short periods. contacted Comet engineer who says its the compressor and will cost almost as much as a new machine to fix it. we are disgusted as its only just over a year old and has been repaired twice already. we would also add that both
the fridge and freezer are now completely out of action and have been all over the Easter period which has caused us much inconvenience. we will take this matter further if no satisfaction is gained from Comet.
Feb 28, 2008 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
49 people viewed this question
Top Haier Refrigerators Experts
Marvin
Marvin
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
