How to resolve a problem
Slow computer If you have a virus program installed, it is most likely is running a scan on your hard disk. It can slow down your computer especially if you have a large hard drive. After scanning is completed then the computer will be faster.
To make your computer (hard disk) lean and mean, uninstall any programs you do not use.
Also you need to maintain your hard disk by running Disk Cleanup this will remove old temp files and old compressed files etc.
This will reduce the number of files the virus scanner has to scan. Plus running Defrag. this makes your files contiguous so the system can access files off the hard drive quicker because it does not work as hard.. Disk Cleanup and Defrag should be carried out at least once a month.
If you have 512Mb of RAM installed then installing more RAM will speed up your computer. After installing your graphics card, you may need to disable the built-in graphics card in the BIOS for the new graphics card to work properly.
Switch ON the PC, boot the PC in
'Safe Mode' by continuously tapping F8 button after you switch On.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->System
Restore
Here you will have to check "Restore computer to an earlier time' and
click Next
Now you will find one Month Calendar window with Dates below, go to
the previous month by clicking the '<' sign in the upper left hand
corner of the Month Calendar and select any date that you see in Bold.
The
detail of that particular date should show "System Checkpoint" and
time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a
reboot.
After reboot Go to 'Start' and then Run
write "msconfig" inside Run tab and press 'enter'
inside the 'System configuration
utility' window click on 'startup' tab then uncheck all the applications except
your current antivirus and press apply then 'ok' and then 'exit without
restart' option.
Now right click My Computer and go to properties tab.
click 'Advanced' tab then under performance menu click on 'settings'
go to 'Advanced' click on 'change' and increase your virtual memory to 2048 in
both spaces.
Now restart windows.
Just do the
following steps and your issue will be resolved.
1) Delete
all unwanted data from Drive C.
2) Delete
all data that you have copied from Drive C to External HDD
3) Open My
computer and go to Tools---> Folder Options---->Click on View Tab---->
Check 'Show hidden files and folders' and select OK.
4) Go to
C:\Documents and Settings\Administrator\Local Settings\Temp and Delete
everything that you see inside Temp Folder
5) Go to
C:\WINDOWS\ here you will find folders like $hf_mig$, here you will have to
Delete all the folders starting and ending with $ sign.
6) Empty
Recycle bin and restart the PC and your issue will be resolved.
The
time on the right hand side box. Select that date. Just do the
following steps and your issue will be resolved. 1) Delete
all unwanted data from Drive C. 2) Delete
all data that you have copied from Drive C to External HDD 3) Open My
Check 'Show hidden files and folders' and select OK. 4) Go to
everything that you see inside Temp Folder 5) Go to
Delete all the folders starting and ending with $ sign. 6) Empty
If you feel that my answers have helped you getting
solution to your problems then please give a vote. Thanks.
reboot.
restart' option.
both spaces.
