Very noisy spin for a couple of washes and now there is cement, oil/grease (a little) and water leaking everywhere from underneath the machine. Outflow pipe is secure and area completely dry so definately coming from underneath machine. Please help, three young kids and loads of washing:-)
SOURCE: Oil/Grease under washer machine
Nash, your unit appears to be made by Whirlpool. (Kenmore doesn't manufacture anything, they purchase from major manufacturers and put the "kenmore" name on them) If, as I suspect, it is made by Whirlpool... the top transmission seal is failed allowing small amounts of water to enter the tranny. The water, being heavier than oil, will displace the oil through the top of the tranny... out through a "weep" hole. The weep hole is not designed to allow fluid to escape, it's designed to allow air to enter and exit the transmission housing, compensating for the heat expansion and contraction of the lubricant that should be contained within. Regardless of the manufacturer, you have a main drive system failure on your hands. It'll only get worse from here. Most manufacturers put a 5 year warranty on their drive-trains, you should call them immediately. If it's over 5 years old, it's a very expensive repair.
SOURCE: Miele washing machine model W713 front load - issues
If it is leaking from the waste pump area it may be blocked by a small piece of clothing like a sock or something similar! This will also cause it to take too long to complete a cycle. Remove the rubber hose onto the waste pump and check inside the hose and the pump, make sure the pump spins freely and that nothing is stuck in the hose pipes leading to the pump
SOURCE: greasy oil and water is leaking from under the washing machine?
Hello, the good news is the water is coming from the pump and is easily replaced, the bad news is if you are seeing a yellow oily substance your transmission has a leak and will go bad at some stage soon. The question here you need to ask yourself is do you want to spend $35 on a new pump when your going to need to buy a new washer? If so pull the machine out and puch it back so it leans against the wall umder it's own weight. wedge some thing underneath the washer so you can access the bottom without the washer falling on you. you will see the pump attached to the motor which is attached to the transmission. remove the 2 clips and 2 pipes from the pump, remove the pump and replace it, reassemble in reverse order, you should be able to see where the leak came from the pump at the point where the motor shaft connected to the pump. Also while you are under there look at the base of the transmission, you should see some oily residue where the transmission fluid is leaking. Hope this helps! if you have any other questions please feel free to comment again. Good Luck!! Mike
SOURCE: I have an LG Tromm WM2277HW front load washing
Escaping water alongside a nasty smell is often the cause of a blocked water pump or resivour the more washs you do the more the lint will build up & the more the lint builds up the more bloked it will become meening the more water that will escape.. this should be an easy fix but not for everyone.. 1st make sure you have disconected all the power supply then check any or all filters you may have after that you will need to look inside to find the water resivour this will be a plastic bottle shaped for your machine just looking at it you will be able to tell if it has a lint or limescale build up if so it will need removing & flushing out.. there may also be an extra filter at the bottom front of your machine if you open this some water will leak out & you will be able to see if you have a lint build up (this will also have the best of your nasty smell in it) the smell is an effect simular to doing a wash & leaving the cloths in the machine for a few days basicly the lint is submerged in water for long periods of time giving it that smell once cleaned out the smell will subside too
Hope this helps
