My LG WM2016CW washer will not turn on. I have checked the circuit breakers, ground protection breakers and the connection to the wall outlet.All are operation and properly connected. I did find out that all i have to do is pull the plug for five or so seconds and the power returns, but after it sit for a little while the power will not turn back on unless i pull the plug. any ideas???
SOURCE: LG WFT1081TP Top load washer
The fuse is located in a black cover. You need to gently pull the front panel out of the way and look to the right of the unit, in the area under where the panel was. There, you will see a black wire running into a black cylindrical case that has a black wire running out of the other end. Heed the warning on the label, please, and make sure that the power is unplugged form the wall. Gently pry open the casing and you will see the fuse within. The ends of the wires just pull off (gently) and then you have the fuse.
Tomorrow I go on a fuse hunt and try this out.
SOURCE: Dishwasher not responding to "power"
Check the door switch. THis will kill all power to machine.
SOURCE: LG Tromm WM2277H washer won't start after tripping breaker
no fuses only control boards.with power off pull the top off and check wires at your power supply board(not the one with buttons). Look for burn or damaged wires. no luck with that, will probably need power board(usually the board that goes out). Call LG and speak to cust service....sometimes will cover the board.
SOURCE: LG Washer wont start, no power
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
SOURCE: The lights on my LG WM2016CW will not come on.
While looking for the fuse, which I could not find despite opening up the machine from the back (and vacuuming underneath--yuck!), I left the washer unplugged for about 30 min. From reading other forums and such, I realized that unplugging for a little while is often the solution because the prolonged (at least 5 min) lack of power triggers the system to reset. Sure enough, when I went back to plug it in and give up for the night, the thing worked fine. Good luck to anyone else out there!
