Garmin Nuvi 40Lm - Gps Receiver Logo
A
Anonymous Posted on Apr 16, 2013
Garminregister my nuv 30/40/50 GPS
Takes forever to download connection and goes no where
2helpful
Will the garmin nuv GPS 750 Work witout a battery? Using the car power adapter only.
Yes.... You can actually take the battery out of the unit and run the unit on the DC car charger, however once you remove the charger, the unit will die immediately.
When I turned on my Garmin nuv 255W Car GPS Receiver it reminded me to update it because my software was over a year old. My question is how do I update if possible without incurring any cost? Andy
Hi soami696,
To update the software for your unit, free of charge, follow these instructions:
1. Go to http://www.garmin.com/products/webupdater, and download WebUpdater to your computer.
2. Connect the GPS unit to your computer using the Mini-USB cable.
3. Run WebUpdater and follow the on-screen instructions.
After confirming that you want to the update, WebUpdater will automatically download the update and install it on your device.
Reboot your GPS receiver, and you should have the latest updated software from Garmin.
For a copy of a manual for your series of GPS units, go to this link and download here:
http://www8.garmin.com/manuals/2675_OwnersManual.pdf
This manual covers operation of several 200 series Garmin GPS Receivers, such as 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275, and 285W, etc.
Let me know how this works out for you, and if you need further assistance, I'll be glad to help. Thanks.
Regards, Bill
How to key in GPS COORDINATES in garmin nuvi GPS
I have problem to keyin GPS coordinate in Garmin nuv
Sep 10, 2010 • Garmin GPS
I can't power up my nuvi
The internal rechargeable battery doesn't last forever and so probably needs replacing.
You haven't said which model you have so I can't provide you with specific information, but if you type your model number plus "battery replacement" into a search engine then you'll find what you need.
Mar 18, 2010 • Garmin GPS
1helpful
Will not aquire satellites
Easy problem to fix. Please see this link for more info:
http://www.sharc.net/gps_antenna_repair.htm
- Jim
My garmin sat nuv wont turn on even after pressing
plug it in to the house or car charger for at least 4 hours, then try again. if it still wont turn on, we can try something else.
bill
Aug 31, 2009 • GPS
Initial gm-510 gps has intermittent gps signal and loose antenna
well a loose antenna can cause intermittent connections, but so can a low battery, despite it being plugged into a power source. Make sure battery is fully chatrged before use. I would suspect the battery chage first. Even get a new battery
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
