I brought this tv in Apr 2012.Its a 40 inch led TV flat screen.
SOURCE: tv turns off
Hi there, my husband fix the problem. My small son had changed the settings for the HDMI. My husband switched the tv to DVD mode started a dvd & changed all the settings back. After changing all the settings he also reboothed the setbox machine.
SOURCE: Samsung flat screen plasma tv 40" with intermitent problem
Many of the parts in these sets are proprietory. The manufacture reps generaly change the complete board to service the sets.
The can be failed and you change them, but you would have to also find the cause of the failure. If not, when you apply the power back again, the new parts will fail again!
Jerry G.
SOURCE: I have 40? LCD Samsung flat screen TV model:
check power supply capacitors..i repair these every day and the power supply is prone to faulty capacitors..the capacitors should have flat tops and if they are bulging or leaking brown fluid, replace
SOURCE: Samsung 40" tv won't turn on
i had the same problem, you'll have to call the samsung service center. You TV's part which looks after the voltage connectivity has failed. This majorly happens due to voltage fluctuations. The part will cost around Rs. 2800 and service charges will be applied by the company.
