I LIVE IN THE COUNTRY AND DONT HAVE WAY OF TRANSPORTING SET CAN I FIX MYSELF OR GET SOME ONE TO COME TO ME THANK YOU
SOURCE: LG 42 plasma power problem
needs power supply Part number 6709900023A
it is a 171 dollar part, you should be able to order through LG,
SOURCE: LG 50PC3D PLASMA WILL NOT TURN ON
Unplug power cord- safety first!
open backcover
check powersupply- top center right is p.s.
top left side of powersupply you'll see 5 capacitor 3300uF 10V.
see any pop up on top? replace it All with same rate or 16v is O.K.
do not use temperature rate 75c. Use 105C.
if you know how to solder. you save $300 least!
SOURCE: 42 LG plasma no picture but sound. found internal
Sounds like it started "Protection Mode" because of a failed electronic part inside the TV. When this happens, the TV will keep turning itself OFF or will not turn ON at all. This keeps the other parts inside from being damaged. Most likely the TV has a power supply related problem.
The common part to go bad for flat panel screens circuit board that powers the screen itself. Most manufactures call it a Backlight Inverter Board.
But, I can't say what is 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptom.
You have a few choices:
1. Best thing to do, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, schematics, test points, and part# lists.Usually, cost under $20. Its the best repair guide material for fixing TVs. And most cases the new part cost less than $15 by searching on the internet with the part number.
2. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
SOURCE: I have an LG plasma TV, model: 50PC1DRA. We had a
Defective power board. Maybe best to call local service man.
