That IBM Netvista should have a model number on the back.
This tells me if the computer is so old it uses an AT power supply, or an ATX power supply; as modern computers do.
http://www.playtool.com/pages/psuconnectors/connectors.html#oldpcThe old AT form factor of Power Supply, used the above type of main power cables.
The Power On switch was usually connected to the Power Supply.
A separate cable went from the front of the computer, connected to a Power On button, to the Power On switch on the Power Supply.
Or a separate Power On switch was mounted to the Power Supply, and a metal rod pushed against it.
The metal rod pushed by a plastic Power On button, in the front of the computer.
The ATX form factor design uses a Soft Power On circuit.
When a Power Supply is plugged into power, there is a constant 5 Volts present.
The 5 Volt Standby Power.
The ATX power on switch is a Momentary Contact Switch.
Pressing it closes the Soft Power On circuit -> Temporarily.
The 5 Volt Standby power is re-routed, and 'excites' the Power Supply, which turns it on.
THIS type of ATX power on switch is common.
It is inside the plastic Power On button assembly,
http://www.directron.com/atxswitch.htmlRegards,
joecoolvette
http://en.wikipedia.org/wiki/Computer_power_supplyhttp://en.wikipedia.org/wiki/Switched-mode_power_supplyhttp://www.hardwaresecrets.com/article/181
